<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.8.000-SNAPSHOT" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85"><br> <parameter key="generator_type" value="comma_separated_text"/><br> <parameter key="number_of_examples" value="100"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="input_csv_text" value="product, retailer, price Product X, Retailer Y, 500 Product X, Retailer Y, 500 Product X, Retailer Y, 550 Product X, Retailer Y, 600 Product X, Retailer Y, 500 Product X, Retailer Y, 600 Product Y, Retailer Y, 500 Product Y, Retailer Y, 500 Product Y, Retailer Y, 550 Product Y, Retailer Y, 600 Product Y, Retailer Y, 500 Product Y, Retailer Y, 600"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="generate_concatenation" compatibility="9.1.000" expanded="true" height="82" name="Generate Concatenation" width="90" x="246" y="85"><br> <parameter key="first_attribute" value="product"/><br> <parameter key="second_attribute" value="retailer"/><br> <parameter key="separator" value="_"/><br> <parameter key="trim_values" value="false"/><br> </operator><br> <operator activated="true" class="operator_toolbox:group_into_collection" compatibility="1.8.000-SNAPSHOT" expanded="true" height="82" name="Group Into Collection" width="90" x="447" y="85"><br> <parameter key="group_by_attribute" value="product_retailer"/><br> <parameter key="group_by_attribute (numerical)" value=""/><br> <parameter key="sorting_order" value="none"/><br> </operator><br> <operator activated="true" class="loop_collection" compatibility="9.1.000" expanded="true" height="82" name="Loop Collection" width="90" x="581" y="85"><br> <parameter key="set_iteration_macro" value="false"/><br> <parameter key="macro_name" value="iteration"/><br> <parameter key="macro_start_value" value="1"/><br> <parameter key="unfold" value="false"/><br> <process expanded="true"><br> <operator activated="true" class="operator_toolbox:generate_session_id" compatibility="1.8.000-SNAPSHOT" expanded="true" height="82" name="Generate Session ID" width="90" x="112" y="34"><br> <parameter key="date_attribute" value="price"/><br> <parameter key="gap_threshold" value="0.0"/><br> <parameter key="gap_unit" value="none"/><br> <parameter key="use_absolutes" value="false"/><br> </operator><br> <operator activated="true" class="remove_duplicates" compatibility="9.1.000" expanded="true" height="103" name="Remove Duplicates" width="90" x="246" y="34"><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="Session id"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="true"/><br> <parameter key="treat_missing_values_as_duplicates" value="false"/><br> </operator><br> <operator activated="true" class="aggregate" compatibility="9.1.000" expanded="true" height="82" name="Aggregate" width="90" x="447" y="34"><br> <parameter key="use_default_aggregation" value="false"/><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="default_aggregation_function" value="average"/><br> <list key="aggregation_attributes"><br> <parameter key="product" value="count"/><br> </list><br> <parameter key="group_by_attributes" value="retailer|product"/><br> <parameter key="count_all_combinations" value="false"/><br> <parameter key="only_distinct" value="false"/><br> <parameter key="ignore_missings" value="true"/><br> </operator><br> <connect from_port="single" to_op="Generate Session ID" to_port="exa"/><br> <connect from_op="Generate Session ID" from_port="exa" to_op="Remove Duplicates" to_port="example set input"/><br> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Aggregate" to_port="example set input"/><br> <connect from_op="Aggregate" from_port="example set output" to_port="output 1"/><br> <portSpacing port="source_single" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="append" compatibility="9.1.000" expanded="true" height="82" name="Append" width="90" x="715" y="85"><br> <parameter key="datamanagement" value="double_array"/><br> <parameter key="data_management" value="auto"/><br> <parameter key="merge_type" value="all"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Concatenation" to_port="example set input"/><br> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Group Into Collection" to_port="exa"/><br> <connect from_op="Group Into Collection" from_port="col" to_op="Loop Collection" to_port="collection"/><br> <connect from_op="Loop Collection" from_port="output 1" to_op="Append" to_port="example set 1"/><br> <connect from_op="Append" from_port="merged set" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
