Using symmetry for modeling simple array
Taram
Taram New Altair Community Member
edited November 2020 in Community Q&A
__Hi everybody.
1. I am trying to use magnetic symmetry to model simple 2 element array (see image and 1.cfx file below). But FEKO 7.0-238289 (we have such license) gives me an error (i've attached image). Can anybody explain me, where is my mistake. User manual tells, that it is possible to model such structure, if 'geometry to be meshed does indeed adhere to
the specified model symmetry (both geometric symmetry as well as symmetry of excitation and
loads where magnetic/electric symmetry is used)'
2. Another question. I calculate magnitude of active reflection coefficient for 2-port circuit in POSTFEKO by summation
 mag( REAL(S11)+REAL(S12) +i*(IMAG(S11)+IMAG(S12)) ) .
Now assume there are 10 ports :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />. Is there any other way to find Active S parameters (or active VSWR)?
  • JIF
    JIF
    edited February 2018
    Hello Taram
    This s a really old version (in my opinion). The oldest I have installed on my system currently is 2017.0. Please try to upgrade.
    The problem in your model is your S-parameter request. The request that you have is for only one of the ports. The resulting model would excite the port, but not the other port and thus your excitation contradicts the specified symmetry. Even if you add the other port to the S-parameter request, you will run into the same problem, since it will excite one port and load all the other ports, then excite the next port. In this process, the symmetry is violated (exciting the one side of the symmetry plane, but not the other).
    I'm not sure why you are using symmetry on such a basic model, but maybe it is just and example. If you want the mesh to be symmetrical, then use geometrical symmetry and you won't run into the problem.
    If you want the active reflection coefficient, simply excite all the ports that you would like to have active an look at the reflection coefficient at the port of interest. I'm not sure what you are trying to calculate with the equation above.
    If you do have a model with 10 or 100 or more ports and you want to add the reflection coefficients in some way, I would use the scripting feature (I can't remember if it is available in version 7.0, but I suspect it might be).
  • Taram
    Hello JIF. First of all, Thank you very much for your answer.
    1.
    __Of course, you are right. I hope we well upgrade this version as soon as possible. Unfortunately, it depend not only on me.
    2.
    __I want to calculate active reflection coefficient Ra, i.e. reflection coefficient, that takes into account energy, that goes to current port from neighboring ports (due to mutual coupling).
    For exhample, when we solve unit cell of infinite array  with periodic boundary condition we obtain Ra. This model automatically accounts mutual cuopling and i don't need to add complex function's by myself.
    __For 2-port network (1 port) active reflection coefficient
    Ra1=(S11*V1+S12*V2)/V1={if all incident field  amplitudes and phases is equal}=S11+S12; (where all function's are complex).
    __In POSTFEKO i have to write Ra1='abs( REAL(S11)+REAL(S12) +i*(IMAG(S11)+IMAG(S12)) ) '.
    __If i need active VSWR (Wa), then in POSTFEKO i must write
    Wa=( 1+ abs( REAL(S11)+REAL(S12) +i*(IMAG(S11)+IMAG(S12)) ) )/(1-abs( REAL(S11)+REAL(S12) +i*(IMAG(S11)+IMAG(S12)) ) );
    __For 3-port network in case of equal incident field amplitudes
    Ra1=S11+s12+s13;
    __In POSTFEKO - Ra1='abs(  REAL(S11)+REAL(S12) +REAL(S13)+i*(IMAG(S11)+IMAG(S12)+IMAG(S13) )  ) '.
    Wa=....
    __I tried to clear for you, what i meant. As far as i understood, there is no built-in functions to calculate Ra and Wa in FEKO 7.0-238289 .
    But may be this useful function available in newer versions of FEKO?
    __Ok. I heard about it, but never used. I prefered CADFEKO and POSTFEKO gui :)). I think it's time to begin to study scripting in FEKO.
    3.
    __Of course real model is more complicated. But i attached here this simple model to show you a problem i stuck on (without of irrelevant geometry). More correct 16 dipoles with ground (look at image with16 dipoles below). There is no dielectric here, but in future dipoles may be on PCB. Of course the first thing, that occurred to me - was to use electric and magnetic symmetry here to reduce memory requirements and computation time. Of course, S11 of full model and S11 of quarter of full model are not the same (take a look at my image 'S_parameters_relation__.png'). But both model allows me to find necessary Active_S11. So for example, i can optimize smaller model to minimize Active_S11, Active_S22, Active_S33 and Active_S44.
    It is sound and logical to use symmetry here. It would be great, if it were possible to reduce model size with such a way.
    __Am i correct, that (sadly) i can't do it in my version of FEKO?  May it is possible in newer versions of FEKO? If not can you tell FEKO team to work on this.
    __Good idea, but...
    'Geometric symmetry does not reduce the number of unknown coefficients in the current basis
    functions. Therefore there is no reduction in memory usage. There is, however, a reduction in
    computation time when the matrix elements are determined..'
    __So geometrical symmetry does not allow me to reduce memory...
    5a841d9fcbd0e_16dipolesarraywithsym__.png.f454b553906a8af56aff207bf835b96c.png5a841d9ad9aa2_Original16dipolesarray__.png.b0fc4810eb0ee93d38206495a56c4cbb.png
