<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="subprocess" compatibility="9.1.000" expanded="true" height="82" name="Subprocess" origin="GENERATED_TUTORIAL" width="90" x="112" y="340"><br> <process expanded="true"><br> <operator activated="true" class="generate_data_user_specification" compatibility="9.1.000" expanded="true" height="68" name="Generate Data by User Specification" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"><br> <list key="attribute_values"><br> <parameter key="Key" value=""good""/><br> <parameter key="Value" value="1"/><br> </list><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="generate_data_user_specification" compatibility="9.1.000" expanded="true" height="68" name="Generate Data by User Specification (2)" origin="GENERATED_TUTORIAL" width="90" x="45" y="136"><br> <list key="attribute_values"><br> <parameter key="Key" value=""bad""/><br> <parameter key="Value" value="-1"/><br> </list><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="append" compatibility="9.1.000" expanded="true" height="103" name="Append" origin="GENERATED_TUTORIAL" width="90" x="179" y="85"><br> <parameter key="datamanagement" value="double_array"/><br> <parameter key="data_management" value="auto"/><br> <parameter key="merge_type" value="all"/><br> </operator><br> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/><br> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/><br> <connect from_op="Append" from_port="merged set" to_port="out 1"/><br> <portSpacing port="source_in 1" spacing="0"/><br> <portSpacing port="sink_out 1" spacing="0"/><br> <portSpacing port="sink_out 2" spacing="0"/><br> </process><br> <description align="center" color="transparent" colored="false" width="126">Generate dummy dictionary</description><br> </operator><br> <operator activated="true" class="operator_toolbox:dictionary_sentiment_learner" compatibility="1.7.000" expanded="true" height="82" name="Dictionary Based Sentiment" origin="GENERATED_TUTORIAL" width="90" x="380" y="340"><br> <parameter key="value_attribute" value="Value"/><br> <parameter key="key_attribute" value="Key"/><br> <parameter key="negation_attribute" value=""/><br> <parameter key="negation_window_size" value="1"/><br> <parameter key="use_symmetric_negation_window" value="false"/><br> </operator><br> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="112" y="34"><br> <parameter key="text" value="the good, the bad and the ugly is a good film"/><br> <parameter key="add label" value="false"/><br> <parameter key="label_type" value="nominal"/><br> </operator><br> <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="246" y="34"><br> <parameter key="mode" value="non letters"/><br> <parameter key="characters" value=".:"/><br> <parameter key="language" value="English"/><br> <parameter key="max_token_length" value="3"/><br> </operator><br> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document (2)" width="90" x="112" y="136"><br> <parameter key="text" value="the good, the bad and the ugly is a bad bad film"/><br> <parameter key="add label" value="false"/><br> <parameter key="label_type" value="nominal"/><br> </operator><br> <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (3)" width="90" x="246" y="136"><br> <parameter key="mode" value="non letters"/><br> <parameter key="characters" value=".:"/><br> <parameter key="language" value="English"/><br> <parameter key="max_token_length" value="3"/><br> </operator><br> <operator activated="true" class="collect" compatibility="9.1.000" expanded="true" height="103" name="Collect" width="90" x="447" y="34"><br> <parameter key="unfold" value="false"/><br> </operator><br> <operator activated="true" class="operator_toolbox:apply_model_documents" compatibility="1.7.000" expanded="true" height="103" name="Apply Model (Documents)" width="90" x="581" y="187"><br> <list key="application_parameters"/><br> </operator><br> <connect from_op="Subprocess" from_port="out 1" to_op="Dictionary Based Sentiment" to_port="exa"/><br> <connect from_op="Dictionary Based Sentiment" from_port="mod" to_op="Apply Model (Documents)" to_port="mod"/><br> <connect from_op="Create Document" from_port="output" to_op="Tokenize (2)" to_port="document"/><br> <connect from_op="Tokenize (2)" from_port="document" to_op="Collect" to_port="input 1"/><br> <connect from_op="Create Document (2)" from_port="output" to_op="Tokenize (3)" to_port="document"/><br> <connect from_op="Tokenize (3)" from_port="document" to_op="Collect" to_port="input 2"/><br> <connect from_op="Collect" from_port="collection" to_op="Apply Model (Documents)" to_port="doc"/><br> <connect from_op="Apply Model (Documents)" from_port="exa" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
