<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="false" class="read_excel" compatibility="9.1.000" expanded="true" height="68" name="Read Excel" width="90" x="246" y="238"><br> <parameter key="excel_file" value="C:\Users\sgolbert\Downloads\Supermarket2014-15.xls"/><br> <parameter key="sheet_selection" value="sheet number"/><br> <parameter key="sheet_number" value="1"/><br> <parameter key="imported_cell_range" value="A1"/><br> <parameter key="encoding" value="SYSTEM"/><br> <parameter key="first_row_as_names" value="true"/><br> <list key="annotations"/><br> <parameter key="date_format" value=""/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="locale" value="English (United States)"/><br> <parameter key="read_all_values_as_polynominal" value="false"/><br> <list key="data_set_meta_data_information"><br> <parameter key="0" value="Day.true.integer.attribute"/><br> <parameter key="1" value="Product.true.polynominal.attribute"/><br> </list><br> <parameter key="read_not_matching_values_as_missings" value="false"/><br> <parameter key="datamanagement" value="double_array"/><br> <parameter key="data_management" value="auto"/><br> </operator><br> <operator activated="false" class="store" compatibility="9.1.000" expanded="true" height="68" name="Store" width="90" x="648" y="238"><br> <parameter key="repository_entry" value="../data/supermarket"/><br> </operator><br> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve supermarket" width="90" x="112" y="34"><br> <parameter key="repository_entry" value="../data/supermarket"/><br> </operator><br> <operator activated="true" class="trim" compatibility="9.1.000" expanded="true" height="82" name="Trim" width="90" x="246" y="34"><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="Product"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="nominal"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="file_path"/><br> <parameter key="block_type" value="single_value"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="single_value"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> </operator><br> <operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace" width="90" x="380" y="34"><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="Product"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="nominal"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="file_path"/><br> <parameter key="block_type" value="single_value"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="single_value"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="replace_what" value="[ ]"/><br> <parameter key="replace_by" value="|"/><br> </operator><br> <operator activated="true" class="set_role" compatibility="9.1.000" expanded="true" height="82" name="Set Role" width="90" x="514" y="34"><br> <parameter key="attribute_name" value="Day"/><br> <parameter key="target_role" value="id"/><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="concurrency:fp_growth" compatibility="9.1.000" expanded="true" height="82" name="FP-Growth" width="90" x="648" y="34"><br> <parameter key="input_format" value="item list in a column"/><br> <parameter key="item_separators" value="|"/><br> <parameter key="use_quotes" value="false"/><br> <parameter key="quotes_character" value="""/><br> <parameter key="escape_character" value="\"/><br> <parameter key="trim_item_names" value="true"/><br> <parameter key="min_requirement" value="support"/><br> <parameter key="min_support" value="0.005"/><br> <parameter key="min_frequency" value="100"/><br> <parameter key="min_items_per_itemset" value="1"/><br> <parameter key="max_items_per_itemset" value="0"/><br> <parameter key="max_number_of_itemsets" value="1000000"/><br> <parameter key="find_min_number_of_itemsets" value="false"/><br> <parameter key="min_number_of_itemsets" value="100"/><br> <parameter key="max_number_of_retries" value="15"/><br> <parameter key="requirement_decrease_factor" value="0.9"/><br> <enumeration key="must_contain_list"/><br> </operator><br> <operator activated="true" class="create_association_rules" compatibility="9.1.000" expanded="true" height="82" name="Create Association Rules" origin="GENERATED_TUTORIAL" width="90" x="782" y="34"><br> <parameter key="criterion" value="confidence"/><br> <parameter key="min_confidence" value="0.1"/><br> <parameter key="min_criterion_value" value="0.8"/><br> <parameter key="gain_theta" value="2.0"/><br> <parameter key="laplace_k" value="1.0"/><br> </operator><br> <connect from_op="Read Excel" from_port="output" to_op="Store" to_port="input"/><br> <connect from_op="Retrieve supermarket" from_port="output" to_op="Trim" to_port="example set input"/><br> <connect from_op="Trim" from_port="example set output" to_op="Replace" to_port="example set input"/><br> <connect from_op="Replace" from_port="example set output" to_op="Set Role" to_port="example set input"/><br> <connect from_op="Set Role" from_port="example set output" to_op="FP-Growth" to_port="example set"/><br> <connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/><br> <connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/><br> <connect from_op="Create Association Rules" from_port="item sets" to_port="result 2"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> <portSpacing port="sink_result 3" spacing="0"/><br> </process><br> </operator><br></process><br><br>
