<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="9.1.000" expanded="true" height="68" name="Generate Data" width="90" x="112" y="187"> <parameter key="target_function" value="sinus classification"/> <parameter key="number_examples" value="100"/> <parameter key="number_of_attributes" value="5"/> <parameter key="attributes_lower_bound" value="-10.0"/> <parameter key="attributes_upper_bound" value="10.0"/> <parameter key="gaussian_standard_deviation" value="10.0"/> <parameter key="largest_radius" value="10.0"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace" width="90" x="380" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="positive"/> <parameter key="replace_by" value="1"/> </operator> <operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace (2)" width="90" x="514" y="187"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="negative"/> <parameter key="replace_by" value="0"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
