<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000-SNAPSHOT" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="136"> <parameter key="generator_type" value="numeric_series"/> <parameter key="number_of_examples" value="10"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"> <parameter key="att_1" value="linear.0\.0.10\.0"/> <parameter key="att_2" value="linear.10\.0.20\.0"/> </list> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Loop Attributes" width="90" x="380" y="136"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="loop_attribute"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="generate_attributes" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="85"> <list key="function_descriptions"> <parameter key="%{loop_attribute}_bis" value="if(eval(%{loop_attribute})>5,"true","false")"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_port="input 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Loop Attributes" to_port="input 1"/> <connect from_op="Loop Attributes" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
