<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000-SNAPSHOT" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="85"> <parameter key="generator_type" value="date_series"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="true"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"> <parameter key="date" value="2019-01-01 00:00:00.1.hour"/> </list> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Generate ID" width="90" x="179" y="85"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="generate_data" compatibility="9.2.000-SNAPSHOT" expanded="true" height="68" name="Generate Data" width="90" x="45" y="187"> <parameter key="target_function" value="random"/> <parameter key="number_examples" value="100"/> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="-10.0"/> <parameter key="attributes_upper_bound" value="10.0"/> <parameter key="gaussian_standard_deviation" value="10.0"/> <parameter key="largest_radius" value="10.0"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="generate_id" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Generate ID (2)" width="90" x="179" y="187"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" breakpoints="after" class="concurrency:join" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Join" width="90" x="313" y="85"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <operator activated="true" class="python_scripting:execute_python" compatibility="9.1.000" expanded="true" height="103" name="Execute Python" width="90" x="581" y="85"> <parameter key="script" value="import pandas as pd # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) def rm_main(data): data = data.resample('D',on = 'date').mean() data = data.reset_index(level = ['date']) data['date'] = data['date'].astype(str) return data"/> <parameter key="use_default_python" value="true"/> <parameter key="package_manager" value="conda (anaconda)"/> </operator> <operator activated="true" class="set_role" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Set Role" width="90" x="715" y="85"> <parameter key="attribute_name" value="date"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Execute Python" to_port="input 1"/> <connect from_op="Execute Python" from_port="output 1" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="subprocess" compatibility="9.1.000" expanded="true" height="82" name="Subprocess" width="90" x="45" y="187"><br> <process expanded="true"><br> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.8.000-SNAPSHOT" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34"><br> <parameter key="generator_type" value="date_series"/><br> <parameter key="number_of_examples" value="5000"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"><br> <parameter key="date" value="2018-01-01 00:00:00.2018-04-01 00:00:00"/><br> </list><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="generate_attributes" compatibility="9.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34"><br> <list key="function_descriptions"><br> <parameter key="value" value="rand()"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/><br> <portSpacing port="source_in 1" spacing="0"/><br> <portSpacing port="sink_out 1" spacing="0"/><br> <portSpacing port="sink_out 2" spacing="0"/><br> </process><br> <description align="center" color="transparent" colored="false" width="126">Generate example data</description><br> </operator><br> <operator activated="true" class="date_to_numerical" compatibility="9.1.000" expanded="true" height="82" name="Date to Numerical" width="90" x="246" y="187"><br> <parameter key="attribute_name" value="date"/><br> <parameter key="time_unit" value="day"/><br> <parameter key="millisecond_relative_to" value="second"/><br> <parameter key="second_relative_to" value="minute"/><br> <parameter key="minute_relative_to" value="hour"/><br> <parameter key="hour_relative_to" value="day"/><br> <parameter key="day_relative_to" value="epoch"/><br> <parameter key="week_relative_to" value="year"/><br> <parameter key="month_relative_to" value="year"/><br> <parameter key="quarter_relative_to" value="year"/><br> <parameter key="half_year_relative_to" value="year"/><br> <parameter key="year_relative_to" value="era"/><br> <parameter key="keep_old_attribute" value="true"/><br> </operator><br> <operator activated="true" class="aggregate" compatibility="9.1.000" expanded="true" height="82" name="Aggregate" width="90" x="380" y="187"><br> <parameter key="use_default_aggregation" value="false"/><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="default_aggregation_function" value="average"/><br> <list key="aggregation_attributes"><br> <parameter key="value" value="average"/><br> </list><br> <parameter key="group_by_attributes" value="date_day"/><br> <parameter key="count_all_combinations" value="false"/><br> <parameter key="only_distinct" value="false"/><br> <parameter key="ignore_missings" value="true"/><br> </operator><br> <operator activated="true" class="aggregate" compatibility="9.1.000" expanded="true" height="82" name="Aggregate (2)" width="90" x="514" y="340"><br> <parameter key="use_default_aggregation" value="false"/><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="default_aggregation_function" value="average"/><br> <list key="aggregation_attributes"><br> <parameter key="date" value="minimum"/><br> </list><br> <parameter key="group_by_attributes" value="date_day"/><br> <parameter key="count_all_combinations" value="false"/><br> <parameter key="only_distinct" value="false"/><br> <parameter key="ignore_missings" value="true"/><br> </operator><br> <operator activated="true" class="rename" compatibility="9.1.000" expanded="true" height="82" name="Rename" width="90" x="648" y="340"><br> <parameter key="old_name" value="minimum(date)"/><br> <parameter key="new_name" value="FirstDateInWindow"/><br> <list key="rename_additional_attributes"/><br> </operator><br> <operator activated="true" class="concurrency:join" compatibility="9.1.000" expanded="true" height="82" name="Join" width="90" x="782" y="187"><br> <parameter key="remove_double_attributes" value="true"/><br> <parameter key="join_type" value="inner"/><br> <parameter key="use_id_attribute_as_key" value="false"/><br> <list key="key_attributes"><br> <parameter key="date_day" value="date_day"/><br> </list><br> <parameter key="keep_both_join_attributes" value="false"/><br> </operator><br> <connect from_op="Subprocess" from_port="out 1" to_op="Date to Numerical" to_port="example set input"/><br> <connect from_op="Date to Numerical" from_port="example set output" to_op="Aggregate" to_port="example set input"/><br> <connect from_op="Aggregate" from_port="example set output" to_op="Join" to_port="left"/><br> <connect from_op="Aggregate" from_port="original" to_op="Aggregate (2)" to_port="example set input"/><br> <connect from_op="Aggregate (2)" from_port="example set output" to_op="Rename" to_port="example set input"/><br> <connect from_op="Rename" from_port="example set output" to_op="Join" to_port="right"/><br> <connect from_op="Join" from_port="join" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> <description align="center" color="yellow" colored="false" height="182" resized="true" width="320" x="471" y="290">Just to have the first day in Window att later. Might be usefule</description><br> </process><br> </operator><br></process><br><br>
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve Lake Huron" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="repository_entry" value="//Samples/Time Series/data sets/Lake Huron"/> </operator> <operator activated="true" class="time_series:process_windows" compatibility="9.1.000" expanded="true" height="82" name="Process Windows" origin="GENERATED_TUTORIAL" width="90" x="380" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="true"/> <parameter key="indices_attribute" value="Date"/> <parameter key="window_size" value="30"/> <parameter key="no_overlapping_windows" value="false"/> <parameter key="step_size" value="1"/> <parameter key="create_horizon_(labels)" value="true"/> <parameter key="horizon_attribute" value="Lake surface level / feet"/> <parameter key="horizon_size" value="1"/> <parameter key="horizon_offset" value="0"/> <parameter key="add_last_index_in_window_attribute" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="time_series:extract_std_descriptive_features" compatibility="9.1.000" expanded="true" height="82" name="Extract Aggregates" origin="GENERATED_TUTORIAL" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="add_time_series_name" value="false"/> <parameter key="sum" value="true"/> <parameter key="mean" value="true"/> <parameter key="geometric_mean" value="true"/> <parameter key="first_quartile" value="true"/> <parameter key="median" value="true"/> <parameter key="third_quartile" value="true"/> <parameter key="min" value="true"/> <parameter key="max" value="true"/> <parameter key="std_deviation" value="true"/> <parameter key="kurtosis" value="true"/> <parameter key="skewness" value="true"/> <parameter key="ignore_invalid_values" value="false"/> </operator> <connect from_port="windowed example set" to_op="Extract Aggregates" to_port="example set"/> <connect from_op="Extract Aggregates" from_port="features" to_port="output 1"/> <portSpacing port="source_windowed example set" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="9.1.000" expanded="true" height="82" name="Append" origin="GENERATED_TUTORIAL" width="90" x="581" y="34"> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> <parameter key="merge_type" value="all"/> </operator> <connect from_op="Retrieve Lake Huron" from_port="output" to_op="Process Windows" to_port="example set"/> <connect from_op="Process Windows" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
