Saved weights with weights to data operator - How can I use them with the select by weight operator?
Hello community,
this might be a rather dumb question, but I am struggling with the way how the weights operators work. I did a filter-based feature selection
with multiple different filters and combined the results in one table. The columns in that table are Attribute, Information Gain, Chi-Squared, etc. The rows look like the following:
Row No. | Attribute | Information Gain | Chi-Quared
1 A 0.59 0.87
2 B 0.26 1
3 C 1 0.67
Now I want to select the top 10 features of my example set using this - unfortunetly I do not understand how I can get the right weight vector to apply in select weights. I can divide the weights table for each attribute again so it only consists of e.g. Attribute and Information Gain, but how can I get those weights applied with the select by weight Operator. I already watched the video by Markus Hoffman, but am still struggling. Any help is appreciated!
1 - 5 of
51
Hi @lionelderkrikor,
I tried that, but it generates a weight vector with only 1s as values. From the RapidMiner Documentation:
This operator simply generates an attribute weights vector with weight 1.0 for each input attribute.
How can I generate a weight vactor that has the weights from my stored exampleSet (which was created with Weights to Data Operator)?
Best regards,
green_tea
Hi @green_tea,
You can not use directly the weights from the output of Weight by Information Gain, Weight by Chi Squared operator(s) ?
Lionel
Lionel
in theory, yes. In practice, I ran 30+ filter-based weight operators with different example sets that took a long time to complete execution. Using the direct weights would require me to run them again for which I lack the time unfortunately.
In the end I found a work around so I didn't check the converters extension @mschmitz. Thanks for the tip though! I will mark the post as solved, but to all future readers, I did not test if it actually works.
1 - 1 of
11
Use the Data to Weights operator.
Lionel
