first of all excuse my bad English. The purpose of my question is that we have to do a of thesis including a data analysis with rapid miner.
I have a dataset with 20146 Customers, the set includes about 60 attributes but just 3 of them are relevant. Let me try to explain it to you in this way. The whole data set is about return rates in warehouse trade. In simple words, how many articles did a customer order and how many of them is he returning instead of buying.
He gave us the following parameters, >40% high return rate, <18 % low return rate, and the 22% in the middle are neither high or low. So we have 3 different classes of customers. they are supposed to be classified with the value : H - high return rate, N - low return rate, - U - unidentified
We have the customer number, the delivered amount of products and the returned amount of products for each customer.
230823, N
230824, H
230825, U
I managed to create a data set that includes the customer number and N and H but I can't define the 22% class that is between high and low. I tried with if function, generate attributes, and so on. Another problem is that when I try to do it with generate attributes it just gives me true or false and that doesn't help me really much.
Does anyone has an idea of how to solve this? I am pretty desperate. I hope you can help me
regards
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve retouren_train" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Local Repository/retouren_train"/>
<operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="85">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="RETOUREN_MENGE|LIEFER_MENGE|KDNR"/>
<operator activated="true" class="generate_attributes" compatibility="9.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="85">
<parameter key="Niedrigretournierer" value="RETOUREN_MENGE/LIEFER_MENGE*100<18"/>
<parameter key="Hochretournierer" value="RETOUREN_MENGE/LIEFER_MENGE*100>40"/>
</list>
<parameter key="keep_all" value="true"/>
<operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace" width="90" x="648" y="187">
<parameter key="attribute" value="Hochretournierer"/>
<parameter key="attributes" value="Hochretournierer"/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="replace_what" value="true"/>
<parameter key="replace_by" value="H"/>
<operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace (2)" width="90" x="246" y="238">
<parameter key="attribute" value="Niedrigretournierer"/>
<parameter key="replace_by" value="N"/>
<operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace (3)" width="90" x="313" y="340">
<parameter key="replace_what" value="false"/>
<operator activated="true" class="replace" compatibility="9.1.000" expanded="true" height="82" name="Replace (4)" width="90" x="514" y="238">
<operator activated="true" class="set_role" compatibility="9.1.000" expanded="true" height="82" name="Set Role" width="90" x="447" y="391">
<parameter key="attribute_name" value="KDNR"/>
<list key="set_additional_roles">
<parameter key="Hochretournierer" value="prediction"/>
<parameter key="Niedrigretournierer" value="prediction"/>
</list>
<operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="581" y="391">
<parameter key="attributes" value="KDNR|Niedrigretournierer"/>
<operator activated="true" class="rename" compatibility="9.1.000" expanded="true" height="82" name="Rename" width="90" x="681" y="289">
<parameter key="old_name" value="Niedrigretournierer"/>
<parameter key="new_name" value="Einteilung Hoch-/Niedrigretournierer"/>
<list key="rename_additional_attributes"/>
<connect from_op="Retrieve retouren_train" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/>
<connect from_op="Replace (2)" from_port="example set output" to_op="Replace (3)" to_port="example set input"/>
<connect from_op="Replace (3)" from_port="example set output" to_op="Replace (4)" to_port="example set input"/>
<connect from_op="Replace (4)" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_port="result 1"/>
</process>
</process>
