Hi, sorry, I'm new to this, I need help.
I try to use a rapid miner process saved in a local repository, I've seen this code in some question:
ProcessStartInfo Info = new ProcessStartInfo("C:/Program Files/Rapid-I/RapidMiner/scripts/rapidminer.bat");
Info.UseShellExecute = false;
Info.ErrorDialog = false;
Info.CreateNoWindow = true;
Info.RedirectStandardOutput = true;
Info.Arguments = "C:/Program Files/Rapid-I/RapidMiner/scripts/01_ParameterOptimization.xml";
Process p = System.Diagnostics.Process.Start(Info);
System.IO.StreamReader oReader2 = p.StandardOutput;
string sRes = oReader2.ReadToEnd();
oReader2.Close();
//All the external programs output is now in sRes
Console.WriteLine(sRes);
Console.ReadLine();Where do I pass the repository route to execute the process?
How do I send the new excel file from which I want to obtain results based on the training set already done?,
