<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="split_data" compatibility="9.1.000" expanded="true" height="103" name="Split Data" width="90" x="246" y="238"> <enumeration key="partitions"> <parameter key="ratio" value="0.6"/> <parameter key="ratio" value="0.4"/> </enumeration> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="concurrency:parallel_random_forest" compatibility="9.1.000" expanded="true" height="103" name="Random Forest" width="90" x="380" y="34"> <parameter key="number_of_trees" value="100"/> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="10"/> <parameter key="apply_pruning" value="false"/> <parameter key="confidence" value="0.1"/> <parameter key="apply_prepruning" value="false"/> <parameter key="minimal_gain" value="0.01"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> <parameter key="random_splits" value="false"/> <parameter key="guess_subset_ratio" value="true"/> <parameter key="subset_ratio" value="0.2"/> <parameter key="voting_strategy" value="confidence vote"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="9.1.000" expanded="true" height="103" name="Multiply" width="90" x="380" y="238"/> <operator activated="true" class="apply_model" compatibility="9.1.000" expanded="true" height="82" name="Apply Model" width="90" x="715" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="model_simulator:model_simulator" compatibility="9.1.000" expanded="true" height="103" name="Model Simulator" width="90" x="782" y="238"/> <connect from_op="Retrieve Iris" from_port="output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Random Forest" to_port="training set"/> <connect from_op="Split Data" from_port="partition 2" to_op="Multiply" to_port="input"/> <connect from_op="Random Forest" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Random Forest" from_port="exampleSet" to_op="Model Simulator" to_port="training data"/> <connect from_op="Multiply" from_port="output 1" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Multiply" from_port="output 2" to_op="Model Simulator" to_port="test data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model" from_port="model" to_op="Model Simulator" to_port="model"/> <connect from_op="Model Simulator" from_port="simulator output" to_port="result 2"/> <connect from_op="Model Simulator" from_port="model output" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator> </process>
