It is explain in the Help--"When split is prevented by prepruning at a certain node this parameter will adjust the number of alternative nodes tested for splitting. Occurs as prepruning runs parallel to the tree generation process. This may prevent splitting at certain nodes, when splitting at that node does not add to the discriminative power of the entire tree. In such a case, alternative nodes are tried for splitting."
but I can not unerstand,Please give me a more clearer explanation
