Auto Model Issue
Judy
Hi
I have try to use the auto model tool for forecasting. The excel data i imported in have 1000 rows. But when the prediction results that is out for the linear model and deep learning, there is only half of it (~500 rows). Why is this so?
Please advice.
Thanks!
Auto Model
lionelderkrikor
Hi
@Judy
It's not an issue. It's an evolution of RapidMiner 9.1.
Now, by default in AutoModel, RapidMiner performs a data split with 60% for training the model and 40% for testing the model.(See the
Split Data
operator in the generated process).
The predictions are only performed on the test set. So for a dataset of around 1000 examples, there are around 0.4 * 1000 = 400 predictions.
I hope it helps,
Lionel
Judy
Hi
@lionelderkrikor
thank you for explaining!
lionelderkrikor
Hi
@Judy
Split Data
I hope it helps,
Lionel
Judy
Hi
@lionelderkrikor
daniel_beck
for a predictive Maintenance Case, i predict a Health Index for each Job of a machine. The Health Index is a simple Value how many percentage of successfull jobs the machine produced.
My plan is to sum up all predicted Health Index Values from Rapidminer and compare them with the real outcome of the machine. So i can see over a timeline, whether the predicted values show more a trend of a higher or lower Health Index.
To do so, i need 100% of the "explained predictions". So far the Automodel restrict it to "40% hold-out set" as written also in the forum. I tried to change this and play with the "Split Data" Operator and the "random seed", but it was not successfull to increase the number of sample sets to export more samples then the 40%.
Any idea from your site to get more samples out for the Export?
Thanks a lot,
Daniel
varunm1
Hi
@daniel_beck
You can use cross-validation operator instead of split data so that you get predictions for all the samples in your dataset.
IngoRM
To be honest, it actually sounds like you want to apply the model on the data you trained it on which is obviously a big no-no. Opening the process and changing it so that it does that is one option. An alternative would be the cross-validation approach
@varunm1
has mentioned, but to be honest, than you end up with predictions from, let's say, ten different models. Not sure how much what tell you that either... Why can't you just sum up the health indices from the hold-out set? That is the only option I can see which has at least a directly interpretable meaning.
Just my 2c,
Ingo
