Hello Guys,
I 'm trying to run processes on Server but i fail everytime! I did go to VIEW DETAILS and get the ERROR MESSAGE:
"Out of memory- The process has failed as it ran out of memory. Try to run the process again with less data or choose another queue with larger Job Containers."
I did as Edin_Klapic had said to me ("You need to assign more RAM to the job agent. The file is agent.properties located in job-agent/home/config.") and assign more RAM to the job agent. I even tried to run a proccess with very very low RAM requirements (some kB) but didn't work!
Any ideas?
I give you the LOG:
2018-12-19 15:00:42.111 INFO 5855 --- [main] c.r.execution.jobcontainer.Application : Starting Application on alex-HP-Compaq-8000-Elite-CMT-PC with PID 5855 (/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/lib/container/rapidminer-jobcontainer-0.4.7.jar started by root in /home/alex/rapidminer-server/rapidminer-server-9.0.4/bin)
2018-12-19 15:00:42.135 INFO 5855 --- [main] c.r.execution.jobcontainer.Application : No active profile set, falling back to default profiles: default
2018-12-19 15:00:50.205 INFO 5855 --- [main] s.c.a.AnnotationConfigApplicationContext : Refreshing org.springframework.context.annotation.AnnotationConfigApplicationContext@2d1ef81a: startup date [Wed Dec 19 15:00:50 EET 2018]; root of context hierarchy
2018-12-19 15:00:54.428 INFO 5855 --- [main] o.s.s.c.ThreadPoolTaskScheduler : Initializing ExecutorService 'taskScheduler'
2018-12-19 15:00:58.428 INFO 5855 --- [main] o.s.j.e.a.AnnotationMBeanExporter : Registering beans for JMX exposure on startup
2018-12-19 15:00:58.442 INFO 5855 --- [main] o.s.c.support.DefaultLifecycleProcessor : Starting beans in phase 0
2018-12-19 15:00:58.602 INFO 5855 --- [taskScheduler-2] c.r.e.j.service.RemoteRepositoryService : Trying to update JWT token from auth properties.
2018-12-19 15:00:58.600 INFO 5855 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 544MB / 500000MB
2018-12-19 15:00:58.623 INFO 5855 --- [taskScheduler-2] c.r.e.j.service.RemoteRepositoryService : Updated JWT token from auth properties file.
2018-12-19 15:00:58.686 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Changing 'user.home' system property to '/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/home/data/jobs/75d9e747-7381-45dc-963b-dd18ba50b7a4'
2018-12-19 15:00:58.686 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Generating new in-memory cipher key
2018-12-19 15:00:59.017 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Loading JDBC properties from '/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/home/resources/jdbc/jdbc_properties.xml'
2018-12-19 15:00:59.580 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Setting pre-defined RapidMiner properties from '/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/home/data/jobs/75d9e747-7381-45dc-963b-dd18ba50b7a4/rapidminer.properties'
2018-12-19 15:00:59.597 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Initializing the RapidMiner Core
2018-12-19 15:00:59.597 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Setting execution mode to 'JOB_CONTAINER'
2018-12-19 15:00:59.711 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Loading bundled extension from '/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/lib/container/plugins'
2018-12-19 15:00:59.713 INFO 5855 --- [main] c.r.e.core.RapidMinerInitializer : Loading custom extensions from '/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/home/resources/extensions'
2018-12-19 15:00:59.730 INFO 5855 --- [main] com.rapidminer : Performing upgrade to version 9.0.003
2018-12-19 15:00:59.946 INFO 5855 --- [main] com.rapidminer : Set locale to en.
2018-12-19 15:01:00.106 INFO 5855 --- [main] PlatformUtilities : rapidminer.home is '/home/alex/rapidminer-server/rapidminer-server-9.0.4/job-agent/lib/container'.
2018-12-19 15:01:00.164 INFO 5855 --- [main] com.rapidminer : Initializing license manager.
2018-12-19 15:01:00.438 INFO 5855 --- [main] com.rapidminer : Cannot access file system in execution mode JOB_CONTAINER. Not loading repositories.
2018-12-19 15:01:03.663 INFO 5855 --- [taskScheduler-1] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 544MB / 500000MB
2018-12-19 15:01:05.307 INFO 5855 --- [main] com.rapidminer : Register plugin: Model Simulator
2018-12-19 15:01:05.307 INFO 5855 --- [main] com.rapidminer : Register plugin: Time Series
2018-12-19 15:01:05.307 INFO 5855 --- [main] com.rapidminer : Register plugin: Professional
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Process Scheduling
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: PMML
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: JDBC Connectors
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Advanced File Connectors
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Productivity
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Social Media
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Legacy Result Access
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Concurrency
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: Remote Repository
2018-12-19 15:01:05.308 INFO 5855 --- [main] com.rapidminer : Register plugin: H2O
2018-12-19 15:01:05.309 INFO 5855 --- [main] com.rapidminer : Register plugin: Cloud Connectivity
2018-12-19 15:01:06.900 INFO 5855 --- [main] com.rapidminer : Registered configurator Twitter Connection.
2018-12-19 15:01:07.458 INFO 5855 --- [main] com.rapidminer : Registered configurator Salesforce Connection.
2018-12-19 15:01:07.458 INFO 5855 --- [main] com.rapidminer : Registered configurator Amazon S3 Connection.
2018-12-19 15:01:07.459 INFO 5855 --- [main] com.rapidminer : Registered configurator Azure Blob Storage Connection.
2018-12-19 15:01:07.472 INFO 5855 --- [main] com.rapidminer : Registered configurator Google Cloud Storage Connection.
2018-12-19 15:01:07.472 INFO 5855 --- [main] com.rapidminer : Registered configurator Dropbox Connection.
2018-12-19 15:01:08.664 INFO 5855 --- [taskScheduler-3] c.r.e.j.service.OutOfMemoryWatchdog : Current memory usage is 576MB / 500000MB
Best Regards,
Tzekas Alexandros
