<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="9.1.000" expanded="true" height="68" name="Generate Data" width="90" x="45" y="85"> <parameter key="target_function" value="random"/> <parameter key="number_examples" value="100"/> <parameter key="number_of_attributes" value="5"/> <parameter key="attributes_lower_bound" value="-10.0"/> <parameter key="attributes_upper_bound" value="10.0"/> <parameter key="gaussian_standard_deviation" value="10.0"/> <parameter key="largest_radius" value="10.0"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="converters:example_set_2_html" compatibility="0.4.001" expanded="true" height="82" name="ExampleSet to HTML" width="90" x="179" y="85"> <parameter key="macro" value="htmlMacro"/> <parameter key="Use a limit on Digits" value="false"/> <parameter key="Number of Digits" value="3"/> <parameter key="HTML class name for the table" value="rapidminer-table"/> </operator> <operator activated="true" class="send_mail" compatibility="9.1.000" expanded="true" height="68" name="Send Mail" width="90" x="313" y="85"> <parameter key="to" value="foo@bar.com"/> <parameter key="subject" value="My ExampleSet"/> <parameter key="use_html" value="true"/> <parameter key="body_html" value="<html> 	<head> 		<title>RapidMiner Mail Message</title> 	</head> 	<body> 		<p>%{htmlMacro} 		</p> 	</body> </html> "/> <list key="headers"/> <parameter key="ignore_errors" value="false"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="ExampleSet to HTML" to_port="example set input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
