<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="45" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/><br> </operator><br> <operator activated="true" class="h2o:generalized_linear_model" compatibility="9.2.000" expanded="true" height="124" name="Generalized Linear Model" width="90" x="179" y="34"><br> <parameter key="family" value="AUTO"/><br> <parameter key="link" value="family_default"/><br> <parameter key="solver" value="AUTO"/><br> <parameter key="reproducible" value="false"/><br> <parameter key="maximum_number_of_threads" value="4"/><br> <parameter key="use_regularization" value="true"/><br> <parameter key="lambda_search" value="false"/><br> <parameter key="number_of_lambdas" value="0"/><br> <parameter key="lambda_min_ratio" value="0.0"/><br> <parameter key="early_stopping" value="true"/><br> <parameter key="stopping_rounds" value="3"/><br> <parameter key="stopping_tolerance" value="0.001"/><br> <parameter key="standardize" value="true"/><br> <parameter key="non-negative_coefficients" value="false"/><br> <parameter key="add_intercept" value="true"/><br> <parameter key="compute_p-values" value="false"/><br> <parameter key="remove_collinear_columns" value="false"/><br> <parameter key="missing_values_handling" value="MeanImputation"/><br> <parameter key="max_iterations" value="0"/><br> <parameter key="specify_beta_constraints" value="false"/><br> <list key="beta_constraints"/><br> <parameter key="max_runtime_seconds" value="0"/><br> <list key="expert_parameters"/><br> </operator><br> <operator activated="true" class="multiply" compatibility="9.2.000" expanded="true" height="103" name="Multiply" width="90" x="313" y="85"/><br> <operator activated="true" class="model_simulator:explain_predictions" compatibility="9.2.000" expanded="true" height="103" name="Explain Predictions" width="90" x="447" y="34"><br> <parameter key="maximal explaining attributes" value="3"/><br> <parameter key="local sample size" value="500"/><br> <parameter key="only create predictions" value="false"/><br> </operator><br> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Generalized Linear Model" to_port="training set"/><br> <connect from_op="Generalized Linear Model" from_port="model" to_op="Explain Predictions" to_port="model"/><br> <connect from_op="Generalized Linear Model" from_port="exampleSet" to_op="Multiply" to_port="input"/><br> <connect from_op="Multiply" from_port="output 1" to_op="Explain Predictions" to_port="training data"/><br> <connect from_op="Multiply" from_port="output 2" to_op="Explain Predictions" to_port="test data"/><br> <connect from_op="Explain Predictions" from_port="visualization output" to_port="result 1"/><br> <connect from_op="Explain Predictions" from_port="importances output" to_port="result 2"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> <portSpacing port="sink_result 3" spacing="0"/><br> </process><br> </operator><br></process>
