Hi there,
I am using the open wordnet dictionary operator along with the extract sentiment (english) operator. I have set up the dictionary path to point to the correct folder. I have a couple 100 text files that I want to analyze, if I analyze just 8 of those files the process runs fine, however if I try run it against 9+ of the text files I get an I/O error that the resource can't be read and parsed.
Is it possible to have the wordnet operator run once and remember the list of words instead of running for each time a new file is captured through the process documents from files operator?
If this is not possible, is there a way to overcome this issue?
Many Thanks.
