stored process
myRM404414
I stored some processes and when I bring them again in "Process area", they appear just as a single operator: I assume that it is the synthesis of all the components used to build the process, but it would be more useful to have all of them in detail. Is there a way to have all the operators of a stored process shown?
Store
BalazsBaranyRM
how did you do the "bring them again" part?
When you drag and drop a process from the repository, you're getting an "Execute Process" operator.
If you use the Open Process function in the menu or the toolbar, you're opening the original process again.
Balázs
Telcontar120
Actually the Execute Process operator is very powerful, because it allows you to call a stored process within other processes. This means that if you need to make changes to the original process, you can do it in one location (the original one) and then all subsequent processes that depend on that process will automatically get the current version when they call it via Execute Process.
You could in fact simply copy all the individual operators from the original process into your later process (using simple copy/paste functionality) but that would be less advantageous because then if you made changes in the original, they would not automatically be reflected in the copy.
So basically, if you don't actually need to change the original process then you are better off calling it via Execute Process. If you do need to change it then you should decouple them and simply use copies of the original process operators.
BalazsBaranyRM
Balázs
Telcontar120
myRM404414
Thanks to both of you. I had seen the Open command but I was disturbed by the window "Save changes to..." that was not very reassuring. And actually I still don't understand why there is this question when I simply try to open a process... what changes is RM talking about if I'm just opening a process? That is to say... what changes whether I answer YES or NO?
myRM404414
Also, lot of times a selected process is not opening. I thought "open" command was like in every SW, but here it seems quite strange.
