<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000-BETA2"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000-BETA2" expanded="true" name="Root" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Sonar" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="concurrency:cross_validation" compatibility="9.1.000-BETA2" expanded="true" height="145" name="Cross Validation (2)" width="90" x="313" y="34"> <parameter key="split_on_batch_attribute" value="false"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_folds" value="10"/> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="stacking" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Stacking" origin="GENERATED_TUTORIAL" width="90" x="112" y="34"> <parameter key="keep_all_attributes" value="true"/> <process expanded="true"> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.1.000-BETA2" expanded="true" height="103" name="Decision Tree" origin="GENERATED_TUTORIAL" width="90" x="112" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <operator activated="true" class="k_nn" compatibility="9.1.000-BETA2" expanded="true" height="82" name="K-NN" origin="GENERATED_TUTORIAL" width="90" x="112" y="187"> <parameter key="k" value="5"/> <parameter key="weighted_vote" value="false"/> <parameter key="measure_types" value="MixedMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="GeneralizedIDivergence"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> </operator> <operator activated="true" class="linear_regression" compatibility="9.1.000-BETA2" expanded="true" height="103" name="Linear Regression" origin="GENERATED_TUTORIAL" width="90" x="112" y="289"> <parameter key="feature_selection" value="M5 prime"/> <parameter key="alpha" value="0.05"/> <parameter key="max_iterations" value="10"/> <parameter key="forward_alpha" value="0.05"/> <parameter key="backward_alpha" value="0.05"/> <parameter key="eliminate_colinear_features" value="true"/> <parameter key="min_tolerance" value="0.05"/> <parameter key="use_bias" value="true"/> <parameter key="ridge" value="1.0E-8"/> </operator> <connect from_port="training set 1" to_op="Decision Tree" to_port="training set"/> <connect from_port="training set 2" to_op="K-NN" to_port="training set"/> <connect from_port="training set 3" to_op="Linear Regression" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="base model 1"/> <connect from_op="K-NN" from_port="model" to_port="base model 2"/> <connect from_op="Linear Regression" from_port="model" to_port="base model 3"/> <portSpacing port="source_training set 1" spacing="0"/> <portSpacing port="source_training set 2" spacing="105"/> <portSpacing port="source_training set 3" spacing="84"/> <portSpacing port="source_training set 4" spacing="0"/> <portSpacing port="sink_base model 1" spacing="0"/> <portSpacing port="sink_base model 2" spacing="105"/> <portSpacing port="sink_base model 3" spacing="84"/> <portSpacing port="sink_base model 4" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Naive Bayes" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="laplace_correction" value="true"/> </operator> <connect from_port="stacking examples" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="stacking model"/> <portSpacing port="source_stacking examples" spacing="0"/> <portSpacing port="sink_stacking model" spacing="0"/> </process> </operator> <connect from_port="training set" to_op="Stacking" to_port="training set"/> <connect from_op="Stacking" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Apply Model" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Performance" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance 1"/> <connect from_op="Performance" from_port="example set" to_port="test set results"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> </process> </operator> <connect from_op="Sonar" from_port="output" to_op="Cross Validation (2)" to_port="example set"/> <connect from_op="Cross Validation (2)" from_port="model" to_port="result 1"/> <connect from_op="Cross Validation (2)" from_port="test result set" to_port="result 2"/> <connect from_op="Cross Validation (2)" from_port="performance 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="21"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator> </process>
