<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000-BETA2"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000-BETA2" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34"> <parameter key="csv_file" value="C:\Users\Lionel\Downloads\RapidMiner_example.csv"/> <parameter key="column_separators" value=";"/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="2"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value="dd.MM.yyyy"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Factory.true.integer.attribute"/> <parameter key="1" value="Material.true.integer.attribute"/> <parameter key="2" value="Material_Description.true.polynominal.attribute"/> <parameter key="3" value="User.true.polynominal.attribute"/> <parameter key="4" value="Department.true.polynominal.attribute"/> <parameter key="5" value="Mfg_Line.true.polynominal.attribute"/> <parameter key="6" value="Order.true.integer.attribute"/> <parameter key="7" value="Order_quantity.true.polynominal.attribute"/> <parameter key="8" value="Baseunit.true.polynominal.attribute"/> <parameter key="9" value="Scrap.true.integer.attribute"/> <parameter key="10" value="Scheduled_start.true.date.attribute"/> <parameter key="11" value="Scheduled_finish.true.date.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="set_macros" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Set Macros" width="90" x="179" y="34"> <list key="macros"> <parameter key="startDate" value="Jan 30,2017"/> <parameter key="endDate" value="Dec 30,2020"/> <parameter key="department" value="Prod2"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="9.1.000-BETA2" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Department.equals.%{department}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Extract Macro" width="90" x="472" y="34"> <parameter key="macro" value="numExamples"/> <parameter key="macro_type" value="number_of_examples"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <operator activated="true" class="concurrency:loop" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Loop" width="90" x="606" y="34"> <parameter key="number_of_iterations" value="%{numExamples}"/> <parameter key="iteration_macro" value="iteration"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="nominal_to_date" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Nominal to Date (4)" width="90" x="45" y="34"> <parameter key="attribute_name" value="Scheduled_start"/> <parameter key="date_type" value="date"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Nominal to Date (5)" width="90" x="179" y="34"> <parameter key="attribute_name" value="Scheduled_finish"/> <parameter key="date_type" value="date"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate Attributes (4)" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="capacity" value="if((date_before(date_parse_custom(%{startDate},"MMM dd,YYYY"),Scheduled_start) == true && date_before(date_parse_custom(%{endDate},"MMM dd,YYYY"),Scheduled_start) == true)|| (date_after(date_parse_custom(%{startDate},"MMM dd,YYYY"),Scheduled_finish) == true && date_after(date_parse_custom(%{endDate},"MMM dd,YYYY"),Scheduled_finish) == true),0,Order_quantity)"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Date to Nominal (6)" width="90" x="514" y="34"> <parameter key="attribute_name" value="Scheduled_start"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Date to Nominal (7)" width="90" x="648" y="34"> <parameter key="attribute_name" value="Scheduled_finish"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <connect from_port="input 1" to_op="Nominal to Date (4)" to_port="example set input"/> <connect from_op="Nominal to Date (4)" from_port="example set output" to_op="Nominal to Date (5)" to_port="example set input"/> <connect from_op="Nominal to Date (5)" from_port="example set output" to_op="Generate Attributes (4)" to_port="example set input"/> <connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Date to Nominal (6)" to_port="example set input"/> <connect from_op="Date to Nominal (6)" from_port="example set output" to_op="Date to Nominal (7)" to_port="example set input"/> <connect from_op="Date to Nominal (7)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="parse_numbers" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Parse Numbers" width="90" x="740" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="capacity"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_character" value=","/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="unparsable_value_handling" value="fail"/> </operator> <operator activated="true" class="aggregate" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Aggregate" width="90" x="901" y="34"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="capacity" value="sum"/> </list> <parameter key="group_by_attributes" value="Department"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate Attributes" width="90" x="1035" y="34"> <list key="function_descriptions"> <parameter key="start_date" value="%{startDate}"/> <parameter key="end_date" value="%{endDate}"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Set Macros" to_port="through 1"/> <connect from_op="Set Macros" from_port="through 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000-BETA2"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000-BETA2" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Read CSV" width="90" x="45" y="34"> <parameter key="csv_file" value="C:\Users\Lionel\Downloads\RapidMiner_example.csv"/> <parameter key="column_separators" value=";"/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="2"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value="dd.MM.yyyy"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Factory.true.integer.attribute"/> <parameter key="1" value="Material.true.integer.attribute"/> <parameter key="2" value="Material_Description.true.polynominal.attribute"/> <parameter key="3" value="User.true.polynominal.attribute"/> <parameter key="4" value="Department.true.polynominal.attribute"/> <parameter key="5" value="Mfg_Line.true.polynominal.attribute"/> <parameter key="6" value="Order.true.integer.attribute"/> <parameter key="7" value="Order_quantity.true.polynominal.attribute"/> <parameter key="8" value="Baseunit.true.polynominal.attribute"/> <parameter key="9" value="Scrap.true.integer.attribute"/> <parameter key="10" value="Scheduled_start.true.date.attribute"/> <parameter key="11" value="Scheduled_finish.true.date.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="set_macros" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Set Macros" width="90" x="179" y="34"> <list key="macros"> <parameter key="startDate" value="Jan 30,2017"/> <parameter key="endDate" value="Dec 30,2020"/> <parameter key="department" value="Prod2"/> <parameter key="department_2" value="Prod1"/> </list> </operator> <operator activated="true" class="filter_examples" compatibility="9.1.000-BETA2" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Department.equals.%{department}"/> <parameter key="filters_entry_key" value="Department.equals.%{department_2}"/> </list> <parameter key="filters_logic_and" value="false"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.1.000-BETA2" expanded="true" height="68" name="Extract Macro" width="90" x="472" y="34"> <parameter key="macro" value="numExamples"/> <parameter key="macro_type" value="number_of_examples"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value=""/> <list key="additional_macros"/> </operator> <operator activated="true" class="concurrency:loop" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Loop" width="90" x="606" y="34"> <parameter key="number_of_iterations" value="%{numExamples}"/> <parameter key="iteration_macro" value="iteration"/> <parameter key="reuse_results" value="true"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="nominal_to_date" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Nominal to Date (4)" width="90" x="45" y="34"> <parameter key="attribute_name" value="Scheduled_start"/> <parameter key="date_type" value="date"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="nominal_to_date" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Nominal to Date (5)" width="90" x="179" y="34"> <parameter key="attribute_name" value="Scheduled_finish"/> <parameter key="date_type" value="date"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate Attributes (4)" width="90" x="313" y="34"> <list key="function_descriptions"> <parameter key="capacity" value="if((date_before(date_parse_custom(%{startDate},"MMM dd,YYYY"),Scheduled_start) == true && date_before(date_parse_custom(%{endDate},"MMM dd,YYYY"),Scheduled_start) == true)|| (date_after(date_parse_custom(%{startDate},"MMM dd,YYYY"),Scheduled_finish) == true && date_after(date_parse_custom(%{endDate},"MMM dd,YYYY"),Scheduled_finish) == true),0,Order_quantity)"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Date to Nominal (6)" width="90" x="514" y="34"> <parameter key="attribute_name" value="Scheduled_start"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="date_to_nominal" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Date to Nominal (7)" width="90" x="648" y="34"> <parameter key="attribute_name" value="Scheduled_finish"/> <parameter key="date_format" value="MMM dd,YYYY"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="keep_old_attribute" value="false"/> </operator> <connect from_port="input 1" to_op="Nominal to Date (4)" to_port="example set input"/> <connect from_op="Nominal to Date (4)" from_port="example set output" to_op="Nominal to Date (5)" to_port="example set input"/> <connect from_op="Nominal to Date (5)" from_port="example set output" to_op="Generate Attributes (4)" to_port="example set input"/> <connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Date to Nominal (6)" to_port="example set input"/> <connect from_op="Date to Nominal (6)" from_port="example set output" to_op="Date to Nominal (7)" to_port="example set input"/> <connect from_op="Date to Nominal (7)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="parse_numbers" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Parse Numbers" width="90" x="740" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="capacity"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_character" value=","/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="unparsable_value_handling" value="fail"/> </operator> <operator activated="true" class="aggregate" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Aggregate" width="90" x="901" y="34"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="capacity" value="sum"/> </list> <parameter key="group_by_attributes" value="Department"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.1.000-BETA2" expanded="true" height="82" name="Generate Attributes" width="90" x="1035" y="34"> <list key="function_descriptions"> <parameter key="start_date" value="%{startDate}"/> <parameter key="end_date" value="%{endDate}"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Set Macros" to_port="through 1"/> <connect from_op="Set Macros" from_port="through 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
