<?xml version="1.0" encoding="UTF-8"?><process version="9.0.003"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.0.003" expanded="true" name="Process"><br> <process expanded="true"><br> <operator activated="true" class="generate_data" compatibility="9.0.003" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34"><br> <parameter key="number_of_attributes" value="105"/><br> </operator><br> <operator activated="true" class="rename_by_replacing" compatibility="9.0.003" expanded="true" height="82" name="Rename by Replacing" width="90" x="179" y="34"><br> <parameter key="attribute_filter_type" value="subset"/><br> <parameter key="regular_expression" value="att.*"/><br> <parameter key="replace_what" value="([0-9]+)"/><br> <parameter key="replace_by" value="1-$1"/><br> </operator><br> <connect from_op="Generate Data" from_port="output" to_op="Rename by Replacing" to_port="example set input"/><br> <connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
