Hey there! I am very new to Rapidminer. When I try to open tiff color image and press the button "start the execution" I get this message :
 Process failed access denied ("java.lang.RuntimePermission" "exitVM.0")
Exception: java.security.AccessControlException
Message: access denied ("java.lang.RuntimePermission" "exitVM.0")
Stack trace:
  java.security.AccessControlContext.checkPermission(AccessControlContext.java:472)
  java.security.AccessController.checkPermission(AccessController.java:884)
  java.lang.SecurityManager.checkPermission(SecurityManager.java:549)
  com.rapidminer.security.PluginSecurityManager.checkPermission(PluginSecurityManager.java:42)
  java.lang.SecurityManager.checkExit(SecurityManager.java:761)
  java.lang.Runtime.exit(Runtime.java:107)
  java.lang.System.exit(System.java:971)
  ij.IJ.getImage(IJ.java:1282)
  cz.vutbr.feec.imageprocessing.op.readWrite.BaseReadImageOperator.readImage(BaseReadImageOperator.java:92)
  cz.vutbr.feec.imageprocessing.op.readWrite.ReadColorImageOperator.doWork(ReadColorImageOperator.java:52)
  com.rapidminer.operator.Operator.execute(Operator.java:1025)
  com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
  com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812)
  com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:807)
  java.security.AccessController.doPrivileged(Native Method)
  com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
  com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428)
  com.rapidminer.Process.execute(Process.java:1322)
  com.rapidminer.Process.run(Process.java:1297)
  com.rapidminer.Process.run(Process.java:1183)
  com.rapidminer.Process.run(Process.java:1136)
  com.rapidminer.Process.run(Process.java:1131)
  com.rapidminer.Process.run(Process.java:1121)
  com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
Ι would appreciate the help.
Thank you
