Good afternoon,
I am facing issues to get an output file for a study on PSIM, which take a parameter (.txt) file and a schematics (.psimsch) as inputs. For the solver inputs arguments, I put first the .psimsch file as input and the .txt file supposed to be created by Hyperstudy to store outputs (with the same name as .psimsch file). However, when I run definition, this .txt file is not created, so that I cannot define any data source in "Define Output Response". Do you have any idea of how I can fix it ?
Thanks for your consideration
