after text processing a document, I want to rename the single words (attributes). Is it possible to connect this with a dictionary? Otherwise I have to do it seperatly for every single Attribute.
A renaming before the text processing is not possible, since it is 3-letter-codes, that could be included in other words as well. In this case, the attributes arc, sas and afl should be replaced:
| arc | sas | bet | hello | house | door | super | afl |
| 1 | 0 | 0 | 0 | 0 | 1 | 0 | 0 |
| 0 | 1 | 1 | 0 | 0 | 0 | 0 | 0 |
Thank you for your help.
