Reading data using field name
robin
I am read a file into RM where there is no header row, each field has the name included in the filed value.
So where a typical CSV file would be:
ice_cream ,chocolate, candy
1,4,5
6,4,2
My files looks like:
"ice_cream"="1","chocolate"="4","candy"="5"
"ice_cream"="6","chocolate"="4","candy"="2"
Various other data mining programs allow for the "retain name" function, how does one deal with this inside of RapidMiner?
The problem that I face is that these files are large, reading them in retaining the field information and replacing it later with an operator uses more than the available system memory.
jczogalla
Hi
@robin
If the data is to be big to fit in in one go, you could try to do a more "manual" approach. As I described in
this thread
, you can use the text extension to split the csv files into lines and the lines into separate values. It should also be possible to then modify each cell value
before
it is put into an example set.
Cheers
Jan
MartinLiebig
Hi
@robin
this format looks very wired. Why is this being used? It produces a ton on overhead while storing it.
Anyway, is the ordering always the same? If yes, you can just read it as polynominals and replace.
BR,
Martin
robin
Yes, it is very heavy. It makes the file enormous. So large that I am unable to read the entire file into RM for processing, just cannot get to the point of using the replace operator.
In other programs there is the ability to read this in as a field name, can one do this in RM?
robin
In Linux I would use the stream editor and do:
sed 's/"ice_cream"="/g'
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="productivity:execute_program" compatibility="9.0.002" expanded="true" height="103" name="Execute Program" width="90" x="246" y="136">
<parameter key="command" value="sed 's/"ice_cream"="/g'"/>
<parameter key="working_directory" value="/Users/robinmeisel/sweets/sweets.flatfile.1"/>
<list key="env_variables"/>
<connect from_op="Execute Program" from_port="out" to_port="result 1"/>
</process>
</process>
But this is a a windows machine I am working on.
MartinLiebig
you would need to read this in completly using Read CSV and then parse it with Replace. There is currently no version of processing a file line by line. It's not to hard to write it though.
BR,
Martin
jczogalla
Hi
@robin
this thread
before
Cheers
Jan
