According to the HELP survival certainty is shown as the following, and must be entered as decimal equivalents (ie. 0.50, etc:
My questions are:
- does this relate directly to the reduction factor Creliability in the standard overall Fatigue Reduction Factor as per a hand-calculated solution for a synthetic SN-curve? (using say Norton's method of solution)
- if it does, then the previous input, Fatigue Strength Reduction Factor, must then be obviously reduced by that amount or there is a possibility of squaring up the effect?
- Why does SimSolid then accept a value of 0 for input of this value - surely from mathematical POV this would result in a singularity?
- Is there anyway of accessing the RainFlow Count data output from a Variable Cycle input for a SimSolid Fatigue study iro a 3D matrix response, or even a 2D data list?
