Would you Please guide me to convert my CSV data file:
    1,A,C,Z,F,G
    2,G,Q,R,C,
    3,Z,G,Q,
    4,C,F,
    5,O,P,
    6,O,X,Y,J,
    7,A,P,X,
I have this table with ~1,000,000 records like these 7 records that you see (**In real Database A,B,C,... are words in string**), Records 1 and 2 are common in G and C value and 2,3 and 1,3 and ...
I want to sync records if they have at least two common value like Records 1 & 2,3,4 (but record 5,6,7 haven't at least 2 shared values with others) and generate a list like this:
    1 A C Z F G Q R
    2 G Q R C A Z F
    3 Z G Q A C F R
    4 C F A Z G Q R
    5 O P
    6 O X Y J
    7 A P X
at the end we must have 4 same records if we sort data and one others without sync:
    1 A C F G Q R Z
    2 A C F G Q R Z
    3 A C F G Q R Z
    4 A C F G Q R Z
    5 O P
    6 J O X Y
    7 A P X
Maybe I do not use good term for my meaning, please see:
    1 A C Z F G
    2 G Q R C
record 1 has C and G common with Record 2 now 1 has not R and Q thus we must have 1 A C Z F G + Q and R and Record 2 has not A,Z and F thus we must have: 2 G Q R C + A,Z and F thus at the end we have:
    1 A C Z F G Q R
    2 G Q R C A Z F
I need all records Respectively in the queue from top to bottom.
for other example: record 4:
1,A,C,Z,F,G
2,G,Q,R,C,
3,Z,G,Q,
4,C,F,
5,O,P,
6,O,X,Y,J,
7,A,P,X,
at first we have :
1 A C Z F G Q R
2 G Q R C A Z F
3 Z G Q A C F R
4,C,F,
5,O,P,
6,O,X,Y,J,
7,A,P,X,
Now at 4 we have C and F common with 1
thus
we generate:
4 C F + a z g q r
at first I wrote a delphi code but it is so slow. second Someone suggest me this groovy code:
    def f=[:]
    new File('Data.csv').readLines().each{
    def items=it.split(',')
    def name
    items.eachWithIndex { String entry, int i ->
    if(i==0){
    name=entry
    else if(entry){
    if(!f[entry])
    f[entry]=[]
    f[entry]<<name
    f.findAll {it.value.size()>1}
It is very fast (because of using a map file I think), but It only finds the common values.
Now I am here,
Please give me any help or suggestion.
Thank you
