I'm using the Extract Entities operator by Aylien and it outputs an Example Set. I want to select only a few attributes using the Select Attribute operator, but it won't take the output from the Extract Entites because it is not an Example Set (Data Table). How can I convert this Example Set output from my Extract to an Example Set (Data Table)?
