I am wondering whether there is any difference in the implementation of the loss optimization function of the MetaCost operator vs the Performance(Costs) operator.  I would not expect there to be. However, I am also seeing significant differences in outcomes when comparing a single DT learner using the Performance(Costs) operator with a cost matrix vs using the MetaCost operator with 1 iteration with an inner DT using the same cost matrix.  There are wide divergences not only in the cost outcome but also other performance metrics such as accuracy and AUC, as well as the resulting models.  See the attached example process:
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.003">
 <context>
 <input/>
 <output/>
 <macros/>
 </context>
 <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
 <process expanded="true">
 <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Sonar" origin="GENERATED_TUTORIAL" width="90" x="112" y="34">
 <parameter key="repository_entry" value="//Samples/data/Sonar"/>
 <operator activated="true" class="multiply" compatibility="9.0.003" expanded="true" height="103" name="Multiply" width="90" x="313" y="34"/>
 <operator activated="true" class="concurrency:cross_validation" compatibility="9.0.003" expanded="true" height="145" name="Cross Validation (MetaCost)" width="90" x="514" y="30">
 <parameter key="use_local_random_seed" value="true"/>
 <operator activated="true" class="metacost" compatibility="9.0.003" expanded="true" height="82" name="MetaCost" origin="GENERATED_TUTORIAL" width="90" x="112" y="34">
 <parameter key="cost_matrix" value="[0.0 2.0;3.0 0.0]"/>
 <parameter key="iterations" value="1"/>
 <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.0.003" expanded="true" height="103" name="Decision Tree (MetaCost)" origin="GENERATED_TUTORIAL" width="90" x="313" y="30"/>
 <connect from_port="training set" to_op="Decision Tree (MetaCost)" to_port="training set"/>
 <connect from_op="Decision Tree (MetaCost)" from_port="model" to_port="model"/>
 <portSpacing port="source_training set" spacing="0"/>
 </process>
 <connect from_port="training set" to_op="MetaCost" to_port="training set"/>
 <connect from_op="MetaCost" from_port="model" to_port="model"/>
 </process>
 <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" origin="GENERATED_TUTORIAL" width="90" x="45" y="34">
 <operator activated="true" class="performance_binominal_classification" compatibility="9.0.003" expanded="true" height="82" name="Performance (MetacCost base)" width="90" x="179" y="34">
 <parameter key="AUC" value="true"/>
 <connect from_port="model" to_op="Apply Model" to_port="model"/>
 <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
 <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (MetacCost base)" to_port="labelled data"/>
 <connect from_op="Performance (MetacCost base)" from_port="performance" to_port="performance 1"/>
 <connect from_op="Performance (MetacCost base)" from_port="example set" to_port="test set results"/>
 <portSpacing port="sink_test set results" spacing="0"/>
 <portSpacing port="sink_performance 1" spacing="0"/>
 <portSpacing port="sink_performance 2" spacing="0"/>
 </process>
 <operator activated="true" class="performance_costs" compatibility="9.0.003" expanded="true" height="82" name="Performance (MetaCost Cost)" width="90" x="648" y="34">
 <enumeration key="class_order_definition"/>
 <operator activated="true" class="concurrency:cross_validation" compatibility="9.0.003" expanded="true" height="145" name="Cross Validation (Costs)" width="90" x="514" y="238">
 <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.0.003" expanded="true" height="103" name="Decision Tree (root)" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"/>
 <connect from_port="training set" to_op="Decision Tree (root)" to_port="training set"/>
 <connect from_op="Decision Tree (root)" from_port="model" to_port="model"/>
 </process>
 <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (2)" origin="GENERATED_TUTORIAL" width="90" x="45" y="30">
 <operator activated="true" class="performance_costs" compatibility="9.0.003" expanded="true" height="82" name="Performance (Cost DT)" width="90" x="179" y="34">
 <connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
 <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
 <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (Cost DT)" to_port="example set"/>
 <connect from_op="Performance (Cost DT)" from_port="example set" to_port="test set results"/>
 <connect from_op="Performance (Cost DT)" from_port="performance" to_port="performance 1"/>
 </process>
 <operator activated="true" class="performance_binominal_classification" compatibility="9.0.003" expanded="true" height="82" name="Performance (Base DT)" width="90" x="648" y="289">
 <connect from_op="Sonar" from_port="output" to_op="Multiply" to_port="input"/>
 <connect from_op="Multiply" from_port="output 1" to_op="Cross Validation (MetaCost)" to_port="example set"/>
 <connect from_op="Multiply" from_port="output 2" to_op="Cross Validation (Costs)" to_port="example set"/>
 <connect from_op="Cross Validation (MetaCost)" from_port="model" to_port="result 1"/>
 <connect from_op="Cross Validation (MetaCost)" from_port="test result set" to_op="Performance (MetaCost Cost)" to_port="example set"/>
 <connect from_op="Cross Validation (MetaCost)" from_port="performance 1" to_port="result 3"/>
 <connect from_op="Performance (MetaCost Cost)" from_port="performance" to_port="result 2"/>
 <connect from_op="Cross Validation (Costs)" from_port="model" to_port="result 4"/>
 <connect from_op="Cross Validation (Costs)" from_port="test result set" to_op="Performance (Base DT)" to_port="labelled data"/>
 <connect from_op="Cross Validation (Costs)" from_port="performance 1" to_op="Performance (Base DT)" to_port="performance"/>
 <connect from_op="Performance (Base DT)" from_port="performance" to_port="result 5"/>
 <portSpacing port="sink_result 2" spacing="18"/>
 <portSpacing port="sink_result 4" spacing="105"/>
 <portSpacing port="sink_result 5" spacing="0"/>
 <portSpacing port="sink_result 6" spacing="0"/>
 </process>
</process>
  @mschmitz any ideas on the underlying algorithms that would be relevant here, or other reasons these might be so different?
