<?xml version="1.0" encoding="UTF-8"?><process version="9.0.003">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.0.003" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="false" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="LoadData" width="90" x="45" y="391">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training BABY_MILK" width="90" x="45" y="238">
            <parameter key="repository_entry" value="Training BABY_MILK"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training CORN_FLOUR" width="90" x="45" y="442">
            <parameter key="repository_entry" value="Training CORN_FLOUR"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training RICE_STARCH" width="90" x="45" y="34">
            <parameter key="repository_entry" value="Training RICE_STARCH"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training SUGAR" width="90" x="45" y="748">
            <parameter key="repository_entry" value="Training SUGAR"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve test BABY_MILK" width="90" x="45" y="340">
            <parameter key="repository_entry" value="test BABY_MILK"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (2)" width="90" x="313" y="238"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test CORN_FLOUR" width="90" x="45" y="544">
            <parameter key="repository_entry" value="Test CORN_FLOUR"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (4)" width="90" x="313" y="493"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test RICE_STARCH" width="90" x="45" y="136">
            <parameter key="repository_entry" value="Test RICE_STARCH"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union" width="90" x="313" y="85"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (5)" width="90" x="447" y="136"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test SUGAR" width="90" x="45" y="646">
            <parameter key="repository_entry" value="Test SUGAR"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (6)" width="90" x="313" y="697"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (7)" width="90" x="514" y="544"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (3)" width="90" x="648" y="289"/>
          <connect from_op="Retrieve Training BABY_MILK" from_port="output" to_op="Union (2)" to_port="example set 1"/>
          <connect from_op="Retrieve Training CORN_FLOUR" from_port="output" to_op="Union (4)" to_port="example set 1"/>
          <connect from_op="Retrieve Training RICE_STARCH" from_port="output" to_op="Union" to_port="example set 1"/>
          <connect from_op="Retrieve Training SUGAR" from_port="output" to_op="Union (6)" to_port="example set 2"/>
          <connect from_op="Retrieve test BABY_MILK" from_port="output" to_op="Union (2)" to_port="example set 2"/>
          <connect from_op="Union (2)" from_port="union" to_op="Union (5)" to_port="example set 2"/>
          <connect from_op="Retrieve Test CORN_FLOUR" from_port="output" to_op="Union (4)" to_port="example set 2"/>
          <connect from_op="Union (4)" from_port="union" to_op="Union (7)" to_port="example set 1"/>
          <connect from_op="Retrieve Test RICE_STARCH" from_port="output" to_op="Union" to_port="example set 2"/>
          <connect from_op="Union" from_port="union" to_op="Union (5)" to_port="example set 1"/>
          <connect from_op="Union (5)" from_port="union" to_op="Union (3)" to_port="example set 1"/>
          <connect from_op="Retrieve Test SUGAR" from_port="output" to_op="Union (6)" to_port="example set 1"/>
          <connect from_op="Union (6)" from_port="union" to_op="Union (7)" to_port="example set 2"/>
          <connect from_op="Union (7)" from_port="union" to_op="Union (3)" to_port="example set 2"/>
          <connect from_op="Union (3)" from_port="union" to_port="out 1"/>
        </process>
      <operator activated="false" class="set_role" compatibility="9.0.003" expanded="true" height="82" name="Set Role" origin="GENERATED_SAMPLE" width="90" x="246" y="391">
        <parameter key="attribute_name" value="KP"/>
      <operator activated="false" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing (3)" origin="GENERATED_SAMPLE" width="90" x="514" y="391">
        <parameter key="window_size" value="18"/>
        <parameter key="label_attribute" value="Close"/>
        <parameter key="stop_on_too_small_dataset" value="false"/>
      <operator activated="false" class="concurrency:cross_validation" compatibility="9.0.003" expanded="true" height="145" name="Cross Validation Keras" origin="GENERATED_TRAINING" width="90" x="715" y="391">
          <operator activated="true" class="keras:sequential" compatibility="1.0.003" expanded="true" height="166" name="Keras Model (2)" width="90" x="112" y="34">
            <parameter key="input shape" value="(18,301)"/>
            <parameter key="loss" value="categorical_crossentropy"/>
            <parameter key="optimizer" value="Adam"/>
            <parameter key="learning rate" value="0.001"/>
            <enumeration key="metric"/>
            <parameter key="epochs" value="256"/>
            <enumeration key="callbacks">
              <parameter key="callbacks" value="TensorBoard(log_dir='./logs', histogram_freq=0, write_graph=True, write_images=False, embeddings_freq=0, embeddings_layer_names=None, embeddings_metadata=None)"/>
            </enumeration>
              <operator activated="true" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (7)" width="90" x="715" y="34">
                <parameter key="filters" value="64"/>
                <parameter key="kernel_size_2d" value="1.1"/>
                <parameter key="kernel_size_3d" value="1.1"/>
                <parameter key="strides_2d" value="1.1"/>
                <parameter key="strides_3d" value="1.1"/>
                <parameter key="padding_1d" value="1."/>
                <parameter key="padding_2d" value="(1, 1)"/>
                <parameter key="padding_3d" value="(1, 1, 1)"/>
                <parameter key="cropping_1d" value="1.1"/>
                <parameter key="size_2d" value="2.2"/>
                <parameter key="size_3d" value="2.2"/>
                <parameter key="data_format" value="None"/>
                <parameter key="dilation_rate_2d" value="1.1"/>
                <parameter key="dilation_rate_3d" value="1.1"/>
                <parameter key="activation_function" value="'relu'"/>
              <operator activated="true" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (7)" width="90" x="849" y="34">
                <parameter key="pool_size_1d" value="5"/>
                <parameter key="pool_size_2d" value="2.2"/>
                <parameter key="pool_size_3d" value="2.2"/>
                <parameter key="strides_1d" value="1"/>
                <parameter key="strides_2d" value="2.2"/>
                <parameter key="strides_3d" value="2.2"/>
              <operator activated="true" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (8)" width="90" x="715" y="136">
              <operator activated="true" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (8)" width="90" x="849" y="136">
                <parameter key="pool_size_1d" value="4"/>
              <operator activated="true" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (9)" width="90" x="715" y="238">
              <operator activated="true" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (9)" width="90" x="849" y="238">
              <operator activated="true" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (10)" width="90" x="715" y="340">
              <operator activated="true" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (10)" width="90" x="849" y="340">
                <parameter key="pool_size_1d" value="3"/>
              <operator activated="true" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (11)" width="90" x="715" y="442">
              <operator activated="true" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (11)" width="90" x="849" y="442">
              <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (2)" width="90" x="1050" y="34">
                <parameter key="layer_type" value="Dropout"/>
                <parameter key="rate" value="0.25"/>
                <parameter key="target_shape" value="1.1"/>
                <parameter key="dims" value="1.1"/>
                <parameter key="repetition_factor" value="2"/>
              <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (4)" width="90" x="1184" y="34">
                <parameter key="layer_type" value="Flatten"/>
              <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (8)" width="90" x="1318" y="34">
                <parameter key="no_units" value="40"/>
                <parameter key="activation_function" value="'sigmoid'"/>
              <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (9)" width="90" x="1318" y="136">
                <parameter key="no_units" value="20"/>
              <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (10)" width="90" x="1318" y="238">
                <parameter key="no_units" value="4"/>
                <parameter key="activation_function" value="'hard_sigmoid'"/>
              <connect from_op="Add Convolutional Layer (7)" from_port="layers 1" to_op="Add Pooling Layer (7)" to_port="layers"/>
              <connect from_op="Add Pooling Layer (7)" from_port="layers 1" to_op="Add Convolutional Layer (8)" to_port="layers"/>
              <connect from_op="Add Convolutional Layer (8)" from_port="layers 1" to_op="Add Pooling Layer (8)" to_port="layers"/>
              <connect from_op="Add Pooling Layer (8)" from_port="layers 1" to_op="Add Convolutional Layer (9)" to_port="layers"/>
              <connect from_op="Add Convolutional Layer (9)" from_port="layers 1" to_op="Add Pooling Layer (9)" to_port="layers"/>
              <connect from_op="Add Pooling Layer (9)" from_port="layers 1" to_op="Add Convolutional Layer (10)" to_port="layers"/>
              <connect from_op="Add Convolutional Layer (10)" from_port="layers 1" to_op="Add Pooling Layer (10)" to_port="layers"/>
              <connect from_op="Add Pooling Layer (10)" from_port="layers 1" to_op="Add Convolutional Layer (11)" to_port="layers"/>
              <connect from_op="Add Convolutional Layer (11)" from_port="layers 1" to_op="Add Pooling Layer (11)" to_port="layers"/>
              <connect from_op="Add Pooling Layer (11)" from_port="layers 1" to_op="Add Core Layer (2)" to_port="layers"/>
              <connect from_op="Add Core Layer (2)" from_port="layers 1" to_op="Add Core Layer (4)" to_port="layers"/>
              <connect from_op="Add Core Layer (4)" from_port="layers 1" to_op="Add Core Layer (8)" to_port="layers"/>
              <connect from_op="Add Core Layer (8)" from_port="layers 1" to_op="Add Core Layer (9)" to_port="layers"/>
              <connect from_op="Add Core Layer (9)" from_port="layers 1" to_op="Add Core Layer (10)" to_port="layers"/>
              <connect from_op="Add Core Layer (10)" from_port="layers 1" to_port="layers 1"/>
              <portSpacing port="sink_layers 1" spacing="0"/>
              <portSpacing port="sink_layers 2" spacing="0"/>
              <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="1114" y="134">Il layer FLATTEN &#232; usato per Input a pi&#249; dimensioni e trasforma un layer a pi&#249; dimensioni in una</description>
            </process>
          <connect from_port="training set" to_op="Keras Model (2)" to_port="training set"/>
          <connect from_op="Keras Model (2)" from_port="model" to_port="model"/>
          <portSpacing port="source_training set" spacing="0"/>
        </process>
          <operator activated="true" class="keras:apply" compatibility="1.0.003" expanded="true" height="82" name="Apply Keras Model (2)" origin="GENERATED_SAMPLE" width="90" x="45" y="34"/>
          <operator activated="true" class="performance" compatibility="9.0.003" expanded="true" height="82" name="Performance (2)" width="90" x="179" y="136"/>
          <operator activated="false" class="performance_classification" compatibility="9.0.003" expanded="true" height="82" name="Performance (3)" width="90" x="179" y="34">
            <parameter key="main_criterion" value="weighted_mean_precision"/>
            <parameter key="weighted_mean_recall" value="true"/>
            <parameter key="weighted_mean_precision" value="true"/>
            <parameter key="squared_correlation" value="true"/>
            <parameter key="cross-entropy" value="true"/>
            <parameter key="skip_undefined_labels" value="false"/>
            <list key="class_weights"/>
          <connect from_port="model" to_op="Apply Keras Model (2)" to_port="model"/>
          <connect from_port="test set" to_op="Apply Keras Model (2)" to_port="unlabelled data"/>
          <connect from_op="Apply Keras Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
          <connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/>
          <connect from_op="Performance (2)" from_port="example set" to_port="test set results"/>
          <portSpacing port="sink_test set results" spacing="0"/>
          <portSpacing port="sink_performance 1" spacing="0"/>
          <portSpacing port="sink_performance 2" spacing="0"/>
        </process>
      <operator activated="true" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="Load TestData 300examples" width="90" x="179" y="187">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve test BABY_MILK (2)" width="90" x="45" y="34">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test CORN_FLOUR (2)" width="90" x="45" y="136">
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (16)" width="90" x="313" y="85"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test RICE_STARCH (2)" width="90" x="45" y="238">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test SUGAR (2)" width="90" x="45" y="340">
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (17)" width="90" x="246" y="238"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (18)" width="90" x="514" y="136"/>
          <connect from_op="Retrieve test BABY_MILK (2)" from_port="output" to_op="Union (16)" to_port="example set 1"/>
          <connect from_op="Retrieve Test CORN_FLOUR (2)" from_port="output" to_op="Union (16)" to_port="example set 2"/>
          <connect from_op="Union (16)" from_port="union" to_op="Union (18)" to_port="example set 1"/>
          <connect from_op="Retrieve Test RICE_STARCH (2)" from_port="output" to_op="Union (17)" to_port="example set 1"/>
          <connect from_op="Retrieve Test SUGAR (2)" from_port="output" to_op="Union (17)" to_port="example set 2"/>
          <connect from_op="Union (17)" from_port="union" to_op="Union (18)" to_port="example set 2"/>
          <connect from_op="Union (18)" from_port="union" to_port="out 1"/>
        </process>
      <operator activated="true" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="Load TrainingData 900Examples" width="90" x="179" y="34">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training BABY_MILK (2)" width="90" x="45" y="34">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training CORN_FLOUR (2)" width="90" x="45" y="136">
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (19)" width="90" x="246" y="85"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training RICE_STARCH (2)" width="90" x="45" y="238">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training SUGAR (2)" width="90" x="45" y="340">
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (21)" width="90" x="246" y="289"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (20)" width="90" x="447" y="187"/>
          <connect from_op="Retrieve Training BABY_MILK (2)" from_port="output" to_op="Union (19)" to_port="example set 1"/>
          <connect from_op="Retrieve Training CORN_FLOUR (2)" from_port="output" to_op="Union (19)" to_port="example set 2"/>
          <connect from_op="Union (19)" from_port="union" to_op="Union (20)" to_port="example set 1"/>
          <connect from_op="Retrieve Training RICE_STARCH (2)" from_port="output" to_op="Union (21)" to_port="example set 1"/>
          <connect from_op="Retrieve Training SUGAR (2)" from_port="output" to_op="Union (21)" to_port="example set 2"/>
          <connect from_op="Union (21)" from_port="union" to_op="Union (20)" to_port="example set 2"/>
          <connect from_op="Union (20)" from_port="union" to_port="out 1"/>
        </process>
      <operator activated="false" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="TrainingData 3000Examples" width="90" x="45" y="34">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training_Rice_Starch" width="90" x="45" y="238">
            <parameter key="repository_entry" value="../Training_Rice_Starch"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training_Baby_Milk" width="90" x="45" y="136">
            <parameter key="repository_entry" value="../Training_Baby_Milk"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Training_Cocoa" width="90" x="45" y="34">
            <parameter key="repository_entry" value="../Training_Cocoa"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (8)" width="90" x="246" y="85"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (10)" width="90" x="447" y="187"/>
          <connect from_op="Retrieve Training_Rice_Starch" from_port="output" to_op="Union (10)" to_port="example set 2"/>
          <connect from_op="Retrieve Training_Baby_Milk" from_port="output" to_op="Union (8)" to_port="example set 2"/>
          <connect from_op="Retrieve Training_Cocoa" from_port="output" to_op="Union (8)" to_port="example set 1"/>
          <connect from_op="Union (8)" from_port="union" to_op="Union (10)" to_port="example set 1"/>
          <connect from_op="Union (10)" from_port="union" to_port="out 1"/>
        </process>
      <operator activated="true" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="Normalize TrainData" width="90" x="313" y="34">
          <operator activated="true" class="multiply" compatibility="9.0.003" expanded="true" height="103" name="Multiply" width="90" x="45" y="136"/>
          <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes (2)" width="90" x="246" y="187">
            <parameter key="attribute" value="KP"/>
          <operator activated="true" class="generate_id" compatibility="9.0.003" expanded="true" height="82" name="Generate ID (3)" width="90" x="782" y="187"/>
          <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="34">
            <parameter key="attributes" value="|Z|Y|X|W|V|U|T|S|R|Q|P|O|N|M|L|KO|KN|KM|KL|KK|KJ|KI|KH|KG|KF|KE|KD|KC|KB|KA|K|JZ|JY|JX|JW|JV|JU|JT|JS|JR|JQ|JP|JO|JN|JM|JL|JK|JJ|JI|JH|JG|JF|JE|JD|JC|JB|JA|J|IZ|IY|IX|IW|IV|IU|IT|IS|IR|IQ|IP|IO|IN|IM|IL|IK|IJ|II|IH|IG|IF|IE|ID|IC|IB|IA|I|HZ|HY|HX|HW|HV|HU|HT|HS|HR|HQ|HP|HO|HN|HM|HL|HK|HJ|HI|HH|HG|HF|HE|HD|HC|HB|HA|H|GZ|GY|GX|GW|GV|GU|GT|GS|GR|GQ|GP|GO|GN|GM|GL|GK|GJ|GI|GH|GG|GF|GE|GD|GC|GB|GA|G|FZ|FY|FX|FW|FV|FU|FT|FS|FR|FQ|FP|FO|FN|FM|FL|FK|FJ|FI|FH|FG|FF|FE|FD|FC|FB|FA|F|EZ|EY|EX|EW|EV|EU|ET|ES|ER|EQ|EP|EO|EN|EM|EL|EK|EJ|EI|EH|EG|EF|EE|ED|EC|EB|EA|E|DZ|DY|DX|DW|DV|DU|DT|DS|DR|DQ|DP|DO|DN|DM|DL|DK|DJ|DI|DH|DG|DF|DE|DD|DC|DB|DA|D|CZ|CY|CX|CW|CV|CU|CT|CS|CR|CQ|CP|CO|CN|CM|CL|CK|CJ|CI|CH|CG|CF|CE|CD|CC|CB|CA|C|BZ|BY|BX|BW|BV|BU|BT|BS|BR|BQ|BP|BO|BN|BM|BL|BK|BJ|BI|BH|BG|BF|BE|BD|BC|BB|BA|B|AZ|AY|AX|AW|AV|AU|AT|AS|AR|AQ|AP|AO|AN|AM|AL|AK|AJ|AI|AH|AG|AF|AE|AD|AC|AB|AA|A"/>
          <operator activated="true" class="normalize" compatibility="9.0.003" expanded="true" height="103" name="Range Trasformation (2)" origin="GENERATED_SAMPLE" width="90" x="380" y="34">
            <parameter key="method" value="range transformation"/>
          <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes (13)" width="90" x="514" y="34">
          <operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing (2)" origin="GENERATED_SAMPLE" width="90" x="648" y="34">
            <parameter key="window_size" value="1"/>
          <operator activated="true" class="generate_id" compatibility="9.0.003" expanded="true" height="82" name="Generate ID (4)" width="90" x="782" y="34"/>
          <operator activated="true" class="concurrency:join" compatibility="9.0.003" expanded="true" height="82" name="Join PCA_Corr" width="90" x="983" y="85">
            <parameter key="use_id_attribute_as_key" value="true"/>
            <list key="key_attributes"/>
          <connect from_port="in 1" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Select Attributes (2)" to_port="example set input"/>
          <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Generate ID (3)" to_port="example set input"/>
          <connect from_op="Generate ID (3)" from_port="example set output" to_op="Join PCA_Corr" to_port="right"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Range Trasformation (2)" to_port="example set input"/>
          <connect from_op="Range Trasformation (2)" from_port="example set output" to_op="Select Attributes (13)" to_port="example set input"/>
          <connect from_op="Select Attributes (13)" from_port="example set output" to_op="Windowing (2)" to_port="example set input"/>
          <connect from_op="Windowing (2)" from_port="example set output" to_op="Generate ID (4)" to_port="example set input"/>
          <connect from_op="Generate ID (4)" from_port="example set output" to_op="Join PCA_Corr" to_port="left"/>
          <connect from_op="Join PCA_Corr" from_port="join" to_port="out 1"/>
          <portSpacing port="source_in 2" spacing="0"/>
        </process>
      <operator activated="true" class="set_role" compatibility="9.0.003" expanded="true" height="82" name="Set Role Train" origin="GENERATED_SAMPLE" width="90" x="447" y="34">
      <operator activated="false" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="TestData 1000examples" width="90" x="45" y="187">
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test_Baby_Milk" width="90" x="45" y="187">
            <parameter key="repository_entry" value="../Test_Baby_Milk"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test_Rice_Starch" width="90" x="45" y="289">
            <parameter key="repository_entry" value="../Test_Rice_Starch"/>
          <operator activated="true" class="retrieve" compatibility="9.0.003" expanded="true" height="68" name="Retrieve Test_Cocoa" width="90" x="45" y="85">
            <parameter key="repository_entry" value="../Test_Cocoa"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (11)" width="90" x="313" y="85"/>
          <operator activated="true" class="union" compatibility="9.0.003" expanded="true" height="82" name="Union (13)" width="90" x="514" y="136"/>
          <connect from_op="Retrieve Test_Baby_Milk" from_port="output" to_op="Union (11)" to_port="example set 2"/>
          <connect from_op="Retrieve Test_Rice_Starch" from_port="output" to_op="Union (13)" to_port="example set 2"/>
          <connect from_op="Retrieve Test_Cocoa" from_port="output" to_op="Union (11)" to_port="example set 1"/>
          <connect from_op="Union (11)" from_port="union" to_op="Union (13)" to_port="example set 1"/>
          <connect from_op="Union (13)" from_port="union" to_port="out 1"/>
        </process>
      <operator activated="false" class="multiply" compatibility="9.0.003" expanded="true" height="68" name="Multiply (4)" width="90" x="581" y="85"/>
      <operator activated="true" class="keras:sequential" compatibility="1.0.003" expanded="true" height="166" name="Keras Model" width="90" x="715" y="34">
        <parameter key="input shape" value="(1,301)"/>
        <parameter key="epochs" value="512"/>
        <parameter key="batch size" value="64"/>
        </enumeration>
          <operator activated="false" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (4)" width="90" x="715" y="34">
          <operator activated="false" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (4)" width="90" x="849" y="34">
          <operator activated="false" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (3)" width="90" x="715" y="136">
          <operator activated="false" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (3)" width="90" x="849" y="136">
          <operator activated="false" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (5)" width="90" x="715" y="238">
          <operator activated="false" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="68" name="Add Pooling Layer (5)" width="90" x="849" y="238">
          <operator activated="false" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (6)" width="90" x="715" y="340">
          <operator activated="false" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="68" name="Add Pooling Layer (6)" width="90" x="849" y="340">
            <parameter key="pool_size_1d" value="1"/>
          <operator activated="true" class="keras:conv_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Convolutional Layer (2)" width="90" x="715" y="442">
          <operator activated="true" class="keras:pooling_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Pooling Layer (2)" width="90" x="849" y="442">
          <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer" width="90" x="1050" y="34">
          <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (3)" width="90" x="1184" y="34">
          <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (5)" width="90" x="1318" y="34">
          <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (11)" width="90" x="1318" y="136">
          <operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (7)" width="90" x="1318" y="238">
          <connect from_op="Add Convolutional Layer (4)" from_port="layers 1" to_op="Add Pooling Layer (4)" to_port="layers"/>
          <connect from_op="Add Pooling Layer (4)" from_port="layers 1" to_op="Add Convolutional Layer (3)" to_port="layers"/>
          <connect from_op="Add Convolutional Layer (3)" from_port="layers 1" to_op="Add Pooling Layer (3)" to_port="layers"/>
          <connect from_op="Add Pooling Layer (3)" from_port="layers 1" to_op="Add Convolutional Layer (5)" to_port="layers"/>
          <connect from_op="Add Convolutional Layer (5)" from_port="layers 1" to_op="Add Pooling Layer (5)" to_port="layers"/>
          <connect from_op="Add Convolutional Layer (6)" from_port="layers 1" to_op="Add Pooling Layer (6)" to_port="layers"/>
          <connect from_op="Add Convolutional Layer (2)" from_port="layers 1" to_op="Add Pooling Layer (2)" to_port="layers"/>
          <connect from_op="Add Pooling Layer (2)" from_port="layers 1" to_op="Add Core Layer" to_port="layers"/>
          <connect from_op="Add Core Layer" from_port="layers 1" to_op="Add Core Layer (3)" to_port="layers"/>
          <connect from_op="Add Core Layer (3)" from_port="layers 1" to_op="Add Core Layer (5)" to_port="layers"/>
          <connect from_op="Add Core Layer (5)" from_port="layers 1" to_op="Add Core Layer (11)" to_port="layers"/>
          <connect from_op="Add Core Layer (11)" from_port="layers 1" to_op="Add Core Layer (7)" to_port="layers"/>
          <connect from_op="Add Core Layer (7)" from_port="layers 1" to_port="layers 1"/>
        </process>
      <operator activated="true" class="subprocess" compatibility="9.0.003" expanded="true" height="82" name="Normalize TestData" width="90" x="313" y="187">
          <operator activated="true" class="multiply" compatibility="9.0.003" expanded="true" height="103" name="Multiply (3)" width="90" x="45" y="136"/>
          <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes (6)" width="90" x="246" y="187">
          <operator activated="true" class="generate_id" compatibility="9.0.003" expanded="true" height="82" name="Generate ID (6)" width="90" x="782" y="187"/>
          <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes (7)" width="90" x="246" y="34">
          <operator activated="true" class="normalize" compatibility="9.0.003" expanded="true" height="103" name="Range Trasformation (3)" origin="GENERATED_SAMPLE" width="90" x="380" y="34">
          <operator activated="true" class="select_attributes" compatibility="9.0.003" expanded="true" height="82" name="Select Attributes (8)" width="90" x="514" y="34">
          <operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing (4)" origin="GENERATED_SAMPLE" width="90" x="648" y="34">
          <operator activated="true" class="generate_id" compatibility="9.0.003" expanded="true" height="82" name="Generate ID (7)" width="90" x="782" y="34"/>
          <operator activated="true" class="concurrency:join" compatibility="9.0.003" expanded="true" height="82" name="Join PCA_Corr (3)" width="90" x="983" y="85">
          <connect from_port="in 1" to_op="Multiply (3)" to_port="input"/>
          <connect from_op="Multiply (3)" from_port="output 1" to_op="Select Attributes (7)" to_port="example set input"/>
          <connect from_op="Multiply (3)" from_port="output 2" to_op="Select Attributes (6)" to_port="example set input"/>
          <connect from_op="Select Attributes (6)" from_port="example set output" to_op="Generate ID (6)" to_port="example set input"/>
          <connect from_op="Generate ID (6)" from_port="example set output" to_op="Join PCA_Corr (3)" to_port="right"/>
          <connect from_op="Select Attributes (7)" from_port="example set output" to_op="Range Trasformation (3)" to_port="example set input"/>
          <connect from_op="Range Trasformation (3)" from_port="example set output" to_op="Select Attributes (8)" to_port="example set input"/>
          <connect from_op="Select Attributes (8)" from_port="example set output" to_op="Windowing (4)" to_port="example set input"/>
          <connect from_op="Windowing (4)" from_port="example set output" to_op="Generate ID (7)" to_port="example set input"/>
          <connect from_op="Generate ID (7)" from_port="example set output" to_op="Join PCA_Corr (3)" to_port="left"/>
          <connect from_op="Join PCA_Corr (3)" from_port="join" to_port="out 1"/>
        </process>
      <operator activated="true" class="set_role" compatibility="9.0.003" expanded="true" height="82" name="Set Role Test" origin="GENERATED_SAMPLE" width="90" x="447" y="187">
      <operator activated="true" class="keras:apply" compatibility="1.0.003" expanded="true" height="82" name="Apply Keras Model" origin="GENERATED_SAMPLE" width="90" x="849" y="187"/>
      <operator activated="true" class="performance" compatibility="9.0.003" expanded="true" height="82" name="Performance" width="90" x="983" y="187">
        <parameter key="use_example_weights" value="false"/>
      <connect from_op="LoadData" from_port="out 1" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Windowing (3)" to_port="example set input"/>
      <connect from_op="Windowing (3)" from_port="example set output" to_op="Cross Validation Keras" to_port="example set"/>
      <connect from_op="Load TestData 300examples" from_port="out 1" to_op="Normalize TestData" to_port="in 1"/>
      <connect from_op="Load TrainingData 900Examples" from_port="out 1" to_op="Normalize TrainData" to_port="in 1"/>
      <connect from_op="Normalize TrainData" from_port="out 1" to_op="Set Role Train" to_port="example set input"/>
      <connect from_op="Set Role Train" from_port="example set output" to_op="Keras Model" to_port="training set"/>
      <connect from_op="Keras Model" from_port="model" to_op="Apply Keras Model" to_port="model"/>
      <connect from_op="Normalize TestData" from_port="out 1" to_op="Set Role Test" to_port="example set input"/>
      <connect from_op="Set Role Test" from_port="example set output" to_op="Apply Keras Model" to_port="unlabelled data"/>
      <connect from_op="Apply Keras Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
      <connect from_op="Performance" from_port="performance" to_port="result 1"/>
    </process>
</process>
Hi, for the university stage I have to classify 4 groups of different signals, and associate them with 4 labels.
Using the cross-validation for the regression classifier and the ANN neural networks, the results are very good (average recognition of 90%).
My goal, however, is to use CNN networks through keras model. In this situation the recognition is not stable, it will change for the same data at each run and is not good like ANN.
For each material I have 1200 examples that are divided between training (900 examples) and testing (300 examples).
If I send you my process.xml, could you try to undestand why the CNN configuration it's not good enought?
Or can you suggest me the best CNN configuration i should use?
The input size is 301 attribute + special attribute(label).
In keras model I used:
- a convolution level with a 64 size filter;
- a level of pooling with layer type MaxPoolind1D;
- a dense level at 40;
- a dense level at 20;
- a dense level at 4;
