I wanted to know if there is already a Case in rapidminer that involves the following problem:
I have 3 machines which are constantly moving between 5 locations, each one has a daily cost of use, a cost of transportation between each point and different delivery in hours per location, I would like to know which is the optimal machine allocation between locations in order to maximize hours of use and have the minimum cost, I have an idea in R with a function and maximize the function with restrictions, but I dont know If I do this in rapidminer?
Thank you
If there is an applied case that is close to this problem it would come very handy!
