How to export the output of RM to a Python file. or any kind of file. how to use the RM info in a Python script manually ?
Hi Paul,
You can do it in many ways, but here are two simple ones.
The advantage of using the Python Extension is that your project is contained within RapidMiner, and that gives you a lot of flexibility (I just tweeted about a case here, where I had to extend RapidMiner's functionalities with Python because there are no lemmatization systems available for Spanish). The advantage of exporting your results to CSV, Excel or a Database are that you aren't limited to Python, and can use Java, Ruby, or whatever you want with the proper libraries.
Hope this helps,
