The "Explain Predictions" operator color-codes the weightings of predictions in terms of their support. See the below screenshot for an example.
Is there a way to copy or export this data out, keeping the color coding intact? I'm aware that I can export this and also the weighting and recreate the color coding for myself, but RapidMiner has already done the work of applying the color coding to the "Explain Predictions" result set for me. I'd love to be able to get it into Excel with color coding intact. If that's not possible, it would even be sufficient to have some way of getting the data out as an image (again, with color coding intact). I've tried screenshotting software like SnagIt that can auto-scroll, but it doesn't seem to pick up RapidMiner's scrollbars.
I didn't see any other forum topics or KB articles on this topic.
Thanks!
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.0.002" expanded="true" height="68" name="Retrieve 20180521 testing" width="90" x="45" y="595">
<parameter key="repository_entry" value="../20180312 JRM/20180521 testing"/>
<operator activated="true" class="multiply" compatibility="9.0.002" expanded="true" height="187" name="Testing" width="90" x="179" y="595"/>
<operator activated="true" class="retrieve" compatibility="9.0.002" expanded="true" height="68" name="Retrieve 20180521 training" width="90" x="45" y="136">
<parameter key="repository_entry" value="../20180312 JRM/20180521 training"/>
<operator activated="true" class="multiply" compatibility="9.0.002" expanded="true" height="166" name="Training" width="90" x="179" y="136"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="CV DL" width="90" x="380" y="238">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="h2o:deep_learning" compatibility="9.0.000" expanded="true" height="82" name="Deep Learning" width="90" x="179" y="34">
<parameter key="activation" value="Rectifier"/>
<enumeration key="hidden_layer_sizes">
<parameter key="hidden_layer_sizes" value="50"/>
</enumeration>
<enumeration key="hidden_dropout_ratios"/>
<parameter key="reproducible_(uses_1_thread)" value="false"/>
<parameter key="epochs" value="10.0"/>
<parameter key="compute_variable_importances" value="false"/>
<parameter key="train_samples_per_iteration" value="-2"/>
<parameter key="adaptive_rate" value="true"/>
<parameter key="epsilon" value="1.0E-8"/>
<parameter key="rho" value="0.99"/>
<parameter key="learning_rate" value="0.005"/>
<parameter key="learning_rate_annealing" value="1.0E-6"/>
<parameter key="learning_rate_decay" value="1.0"/>
<parameter key="momentum_start" value="0.0"/>
<parameter key="momentum_ramp" value="1000000.0"/>
<parameter key="momentum_stable" value="0.0"/>
<parameter key="nesterov_accelerated_gradient" value="true"/>
<parameter key="standardize" value="true"/>
<parameter key="L1" value="1.0E-5"/>
<parameter key="L2" value="0.0"/>
<parameter key="max_w2" value="10.0"/>
<parameter key="loss_function" value="Automatic"/>
<parameter key="distribution_function" value="AUTO"/>
<parameter key="early_stopping" value="false"/>
<parameter key="stopping_rounds" value="1"/>
<parameter key="stopping_metric" value="AUTO"/>
<parameter key="stopping_tolerance" value="0.001"/>
<parameter key="missing_values_handling" value="MeanImputation"/>
<parameter key="max_runtime_seconds" value="0"/>
<list key="expert_parameters"/>
<list key="expert_parameters_"/>
<connect from_port="training set" to_op="Deep Learning" to_port="training set"/>
<connect from_op="Deep Learning" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.0.002" expanded="true" height="82" name="Apply Model (2)" width="90" x="112" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance" compatibility="9.0.002" expanded="true" height="82" name="Performance DL" width="90" x="313" y="34">
<parameter key="use_example_weights" value="true"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance DL" to_port="labelled data"/>
<connect from_op="Performance DL" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance DL" from_port="example set" to_port="test set results"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="CV DT" width="90" x="380" y="442">
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.0.002" expanded="true" height="103" name="Decision Tree" width="90" x="179" y="34">
<parameter key="criterion" value="gain_ratio"/>
<parameter key="maximal_depth" value="20"/>
<parameter key="apply_pruning" value="true"/>
<parameter key="confidence" value="0.35"/>
<parameter key="apply_prepruning" value="true"/>
<parameter key="minimal_gain" value="0.1"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.0.002" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<operator activated="true" class="performance" compatibility="9.0.002" expanded="true" height="82" name="Performance DT" width="90" x="313" y="34">
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance DT" to_port="labelled data"/>
<connect from_op="Performance DT" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance DT" from_port="example set" to_port="test set results"/>
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="CV LR" width="90" x="380" y="34">
<operator activated="true" class="h2o:logistic_regression" compatibility="9.0.000" expanded="true" height="124" name="Logistic Regression" width="90" x="179" y="34">
<parameter key="solver" value="AUTO"/>
<parameter key="reproducible" value="false"/>
<parameter key="maximum_number_of_threads" value="4"/>
<parameter key="use_regularization" value="false"/>
<parameter key="lambda_search" value="false"/>
<parameter key="number_of_lambdas" value="0"/>
<parameter key="lambda_min_ratio" value="0.0"/>
<parameter key="early_stopping" value="true"/>
<parameter key="stopping_rounds" value="3"/>
<parameter key="non-negative_coefficients" value="false"/>
<parameter key="add_intercept" value="true"/>
<parameter key="compute_p-values" value="true"/>
<parameter key="remove_collinear_columns" value="true"/>
<parameter key="max_iterations" value="0"/>
<connect from_port="training set" to_op="Logistic Regression" to_port="training set"/>
<connect from_op="Logistic Regression" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.0.002" expanded="true" height="82" name="Apply Model (3)" width="90" x="112" y="34">
<operator activated="true" class="performance" compatibility="9.0.002" expanded="true" height="82" name="Performance LR" width="90" x="313" y="34">
<connect from_port="model" to_op="Apply Model (3)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance LR" to_port="labelled data"/>
<connect from_op="Performance LR" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance LR" from_port="example set" to_port="test set results"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.0.002" expanded="true" height="82" name="DT Test" width="90" x="581" y="595">
<operator activated="true" class="write_excel" compatibility="9.0.002" expanded="true" height="82" name="DT Write" width="90" x="916" y="595">
<parameter key="excel_file" value="C:\Users\zsherwin\Desktop\rapidminer\output_dt.xlsx"/>
<parameter key="file_format" value="xlsx"/>
<parameter key="sheet_name" value="RapidMiner Data"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="number_format" value="#.0"/>
<operator activated="true" class="jdbc_connectors:write_database" compatibility="9.0.002" expanded="true" height="68" name="DT Write Database" width="90" x="983" y="493">
<parameter key="define_connection" value="predefined"/>
<parameter key="connection" value="BERCMDS"/>
<parameter key="database_system" value="MySQL"/>
<parameter key="use_default_schema" value="true"/>
<parameter key="table_name" value="jrm.BER_RAPIDMINER_DT_OUTPUT_20180521"/>
<parameter key="overwrite_mode" value="none"/>
<parameter key="set_default_varchar_length" value="false"/>
<parameter key="default_varchar_length" value="128"/>
<parameter key="add_generated_primary_keys" value="false"/>
<parameter key="db_key_attribute_name" value="generated_primary_key"/>
<parameter key="batch_size" value="1"/>
<operator activated="true" class="model_simulator:explain_predictions" compatibility="9.0.001" expanded="true" height="103" name="DT Explain Predictions" width="90" x="782" y="595">
<parameter key="maximal explaining attributes" value="3"/>
<parameter key="local sample size" value="500"/>
<operator activated="true" class="apply_model" compatibility="9.0.002" expanded="true" height="82" name="DL Test" width="90" x="581" y="391">
<operator activated="true" class="model_simulator:explain_predictions" compatibility="9.0.001" expanded="true" height="103" name="DL Explain Predictions" width="90" x="782" y="391">
<operator activated="true" class="write_excel" compatibility="9.0.002" expanded="true" height="82" name="DL Write" width="90" x="916" y="391">
<parameter key="excel_file" value="C:\Users\zsherwin\Desktop\rapidminer\output_dl.xlsx"/>
<operator activated="true" class="jdbc_connectors:write_database" compatibility="9.0.002" expanded="true" height="68" name="DL Write Database (2)" width="90" x="983" y="289">
<parameter key="table_name" value="jrm.BER_RAPIDMINER_DL_OUTPUT_20180521"/>
<operator activated="true" class="apply_model" compatibility="9.0.002" expanded="true" height="82" name="LR Test" width="90" x="581" y="187">
<operator activated="true" class="model_simulator:explain_predictions" compatibility="9.0.001" expanded="true" height="103" name="LR Explain Predictions" width="90" x="782" y="187">
<operator activated="true" class="write_excel" compatibility="9.0.002" expanded="true" height="82" name="LR Write" width="90" x="916" y="187">
<parameter key="excel_file" value="C:\Users\zsherwin\Desktop\rapidminer\output_lr.xlsx"/>
<operator activated="true" class="jdbc_connectors:write_database" compatibility="9.0.002" expanded="true" height="68" name="LR Write Database (3)" width="90" x="983" y="85">
<parameter key="table_name" value="jrm.BER_RAPIDMINER_LR_OUTPUT_20180521"/>
<connect from_op="Retrieve 20180521 testing" from_port="output" to_op="Testing" to_port="input"/>
<connect from_op="Testing" from_port="output 1" to_op="DT Test" to_port="unlabelled data"/>
<connect from_op="Testing" from_port="output 2" to_op="DT Explain Predictions" to_port="test data"/>
<connect from_op="Testing" from_port="output 3" to_op="DL Test" to_port="unlabelled data"/>
<connect from_op="Testing" from_port="output 4" to_op="LR Test" to_port="unlabelled data"/>
<connect from_op="Testing" from_port="output 5" to_op="DL Explain Predictions" to_port="test data"/>
<connect from_op="Testing" from_port="output 6" to_op="LR Explain Predictions" to_port="test data"/>
<connect from_op="Retrieve 20180521 training" from_port="output" to_op="Training" to_port="input"/>
<connect from_op="Training" from_port="output 1" to_op="CV LR" to_port="example set"/>
<connect from_op="Training" from_port="output 2" to_op="DL Explain Predictions" to_port="training data"/>
<connect from_op="Training" from_port="output 3" to_op="LR Explain Predictions" to_port="training data"/>
<connect from_op="Training" from_port="output 4" to_op="CV DT" to_port="example set"/>
<connect from_op="Training" from_port="output 5" to_op="CV DL" to_port="example set"/>
<connect from_op="CV DL" from_port="model" to_op="DL Test" to_port="model"/>
<connect from_op="CV DL" from_port="performance 1" to_port="result 11"/>
<connect from_op="CV DT" from_port="model" to_op="DT Test" to_port="model"/>
<connect from_op="CV DT" from_port="example set" to_op="DT Explain Predictions" to_port="training data"/>
<connect from_op="CV DT" from_port="performance 1" to_port="result 10"/>
<connect from_op="CV LR" from_port="model" to_op="LR Test" to_port="model"/>
<connect from_op="CV LR" from_port="performance 1" to_port="result 12"/>
<connect from_op="DT Test" from_port="labelled data" to_op="DT Write" to_port="input"/>
<connect from_op="DT Test" from_port="model" to_op="DT Explain Predictions" to_port="model"/>
<connect from_op="DT Write" from_port="through" to_op="DT Write Database" to_port="input"/>
<connect from_op="DT Write Database" from_port="through" to_port="result 3"/>
<connect from_op="DT Explain Predictions" from_port="visualization output" to_port="result 4"/>
<connect from_op="DT Explain Predictions" from_port="importances output" to_port="result 5"/>
<connect from_op="DL Test" from_port="labelled data" to_op="DL Write" to_port="input"/>
<connect from_op="DL Test" from_port="model" to_op="DL Explain Predictions" to_port="model"/>
<connect from_op="DL Explain Predictions" from_port="visualization output" to_port="result 6"/>
<connect from_op="DL Explain Predictions" from_port="importances output" to_port="result 7"/>
<connect from_op="DL Write" from_port="through" to_op="DL Write Database (2)" to_port="input"/>
<connect from_op="DL Write Database (2)" from_port="through" to_port="result 2"/>
<connect from_op="LR Test" from_port="labelled data" to_op="LR Write" to_port="input"/>
<connect from_op="LR Test" from_port="model" to_op="LR Explain Predictions" to_port="model"/>
<connect from_op="LR Explain Predictions" from_port="visualization output" to_port="result 8"/>
<connect from_op="LR Explain Predictions" from_port="importances output" to_port="result 9"/>
<connect from_op="LR Write" from_port="through" to_op="LR Write Database (3)" to_port="input"/>
<connect from_op="LR Write Database (3)" from_port="through" to_port="result 1"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
<portSpacing port="sink_result 9" spacing="0"/>
<portSpacing port="sink_result 10" spacing="0"/>
<portSpacing port="sink_result 11" spacing="0"/>
<portSpacing port="sink_result 12" spacing="0"/>
<portSpacing port="sink_result 13" spacing="0"/>
</process>
</process>
