When I excute the programm Backward Elimination, I receive the warning "Attribute not found". Within "Set Role" operator, I select MEDV as Attribute. Enclosed the XML file and the CSV file.
Thanks in advance for your support.
Maerkli
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.0.001" expanded="true" height="68" name="Retrieve 12_Feature_12.5_bos_hous_labeled" width="90" x="45" y="85">
<parameter key="repository_entry" value="12_Feature_12.5_bos_hous_labeled"/>
<operator activated="true" class="optimize_selection_backward" compatibility="9.0.001" expanded="true" height="103" name="Backward Elimination" width="90" x="246" y="34">
<parameter key="stopping_behavior" value="with decrease of more than"/>
<parameter key="maximal_relative_decrease" value="0.05"/>
<operator activated="true" class="set_role" compatibility="9.0.001" expanded="true" height="82" name="Set Role" width="90" x="112" y="34">
<parameter key="attribute_name" value="MEDV"/>
<list key="set_additional_roles">
<parameter key="MEDV" value="label"/>
</list>
<operator activated="true" class="split_validation" compatibility="9.0.001" expanded="true" height="124" name="Validation" width="90" x="246" y="34">
<parameter key="sampling_type" value="shuffled sampling"/>
<operator activated="true" class="linear_regression" compatibility="9.0.001" expanded="true" height="103" name="Linear Regression" width="90" x="179" y="34">
<parameter key="feature_selection" value="none"/>
<connect from_port="training" to_op="Linear Regression" to_port="training set"/>
<connect from_op="Linear Regression" from_port="model" to_port="model"/>
<connect from_op="Linear Regression" from_port="weights" to_port="through 1"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_through 2" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_regression" compatibility="9.0.001" expanded="true" height="82" name="Performance" width="90" x="112" y="165">
<parameter key="main_criterion" value="correlation"/>
<parameter key="absolute_error" value="true"/>
<parameter key="squared_correlation" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_through 2" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="example set" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="true" class="linear_regression" compatibility="9.0.001" expanded="true" height="103" name="Linear Regression (2)" width="90" x="447" y="187">
<parameter key="feature_selection" value="greedy"/>
<connect from_op="Retrieve 12_Feature_12.5_bos_hous_labeled" from_port="output" to_op="Backward Elimination" to_port="example set"/>
<connect from_op="Backward Elimination" from_port="example set" to_op="Linear Regression (2)" to_port="training set"/>
<connect from_op="Backward Elimination" from_port="attribute weights" to_port="result 2"/>
<connect from_op="Backward Elimination" from_port="performance" to_port="result 3"/>
<connect from_op="Linear Regression (2)" from_port="model" to_port="result 1"/>
<description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="89" y="261">Final setup of the backward elimination wrapper process.</description>
</process>
</process>
