Communications link failure
njhelloworld
njhelloworld New Altair Community Member
edited November 5 in Community Q&A
I guess no one ever posted a sloved solution with this problem, so I wanted to post this again.. HELP!!! something went wrong during installation..Communications Link Failure the last packet sent successfully.... Attached is the image for the error.. please HELP ME!!! T_T. How to do this??
Best Answer
  • rfuentealba
    rfuentealba New Altair Community Member
    Answer ✓
    Hi @njhelloworld,
    If you can open the MySQL port with the browser, it's not a MySQL connection but a Web connection, e.g., you are configuring https://127.0.0.1:8080/ instead of mysql://root:password@127.0.0.1:3306/database?encoding=utf-8. If that is the case, I would double check the MySQL connection settings, as MySQL is not HTTP.
    All the best,
  • njhelloworld
    I can sense that somethings wrong with the rapidminer server of the connection
  • BalazsBaranyRM
    BalazsBaranyRM New Altair Community Member
    this is a MySQL error message. It is coming from the JDBC driver so that part of the setup is correct.
    However, the connection information (host name, port) is probably not right.
    Balázs
  • njhelloworld
    T_T ..the hostname with port can be opened in the browser without rapidminer, I guess the hostname and port are working properly
    @BalazsBarany wrote:
    Balázs
  • rfuentealba
    Answer ✓
    Hi @njhelloworld,
    All the best,
