I installed RapidMiner 9.0 studio. Started and performed a basic retrieve operations. On parameters I gave Titanic data set. Connected the the operator to ouput port. Clicked on Run button. Expected to see, Titanic data in Result tab, as I used to see in previous versions of RapidMiner. Nothing, absolutely, nothing happens. It dosen't tell me if there is an error, or it is successful. If it successful, why the table is not showing up in result panel.
Tried out Turbo prep with A kaggle dataset. After going thru all the stpeps as directed, I am not sure, what will happen next, there is no direction, your data prep is finished, go here and see results. As said before, clicking on Run does not do anything. Same with Auto modelling. Release 8.x , Automodel used to give results. Now I dont if I should wait for ever, click run button go to result tab. If I do, Turboprep, Does the data alone changes or underlying process also changes ? Because I created a repository and did some manual processing of data wrangling. Turboprep, neither changed the data in repository already exsisting nor the associated process. Sorry for long one, but first time, very frustrated with Rapid Miner. Pls help
