I installed Rapid Miner Version 9.0 on windows 10 Notebook. However, rapid miner cannot open to use. It shows the messages on the images.
I'm also facing the same proble
hello @sukanyadedkaew1 - can you please send me your rapidminer-studio.log file via private message (it is located in your home -> .RapidMiner folder). Thank you!
Scott
Hello Scott ,
Please look the rapidminer-studio.log files in this link. https://we.tl/ISkx6L15zB Thank you.
Took
Hi @sukanyadedkaew1,
You have some .lock files in the folder you sent.
Please, do the following:
Basically, if you executed RapidMiner Studio and the last time it was forcefully shutdown, it had no time to delete these files, that might be preventing the proper recovery of RapidMiner.
Hope this helps,
All the best,
Dear Rodrigo Fuentealba Cartes:
Do I only delete the rapidminer.lock and safeMode.lock files in my notebook? When I deleted these files, must I inform you?
Thank you.
Yeah, if you think it makes you more comfortable, we can chat on hangouts and then inform others so that they can learn what to do if they have the same issue. Write me a private message so that we can check up the details.
I already deleletd the rapidminer.lock and safeMode.lock files in my notebook. Thank you.
Best regards,
@sukanyadedkaew1, did you run RapidMiner Studio again? Did it work?
RapidMiner run but it cannot to use. It still starting all the time.
Now I loaded and installed Rapid Miner Version 9.0 on Windows 10 Pro again. I saw the message as the attached file. Please recommend me. I cannot open to use it.
No idea, sorry mate!
Perhaps at this point it is a good idea to backup your ".RapidMiner" folder on your home directory and restart with a fresh one. However, you will need to install the extensions and export your data again.
Someone else might have another solution (cc @lionelderkrikor, perhaps you can come up with a better solution).
Rodrigo.
hi @sukanyadedkaew1 yes I would concur with @rfuentealba. Make a copy of your .RapidMiner and move it somewhere else first, then delete all the contents of the .RapidMiner folder. Then restart RapidMiner.
there is another possibility in that you downloaded the 64-bit version of RapidMiner but your computer is 32-bit. That would cause a similar result.
Hello All,
I copied RapidMiner Folder from Drive C. to Drive D. But I cannot delete the whole files from Drive C. Therefore, I removed RapidMinder from Control Panel. And I restart my notebook. Later, I can delete the whole file from Drive C. and Drive D. Then, I download RapidMiner Studio 9.0 again. My notebook uses Windows 10 (64 bit). I installed RapidMinder on Drive D. but It shows the same message. RapidMinder cannot open to use.
I have some several questions as the below following:
Thanks
Best ragards,
Sukanya Dedkaew
let me clear a few things up and try to help:
Marco
Hi All,
As your first question : What happens when you click "Disable extensions"?The answer : When I clicked at the button "Disable extensions", RapidMiner is starting all the time as the below image.
As your second question : When you delete the safeMode.lock file inside your C:\Users\yourname\.RapidMiner folder, what happens on the next Studio start? The answer : When I deleted the safeMode.lock file at my C:\Users\Administrator\.RapidMiner, I doubleclick for opening RapidMiner Program,it still is starting as the below image.
Thank you for helping.
Thank you! Could you then please try to start Studio by double-clicking the "RapidMiner-Studio.bat" file instead of the "RapidMiner-Studio.exe" file? This will open a commandline window which should output some interesting stuff. I would like to see what it says. Please add a screenshot of the things it prints out.
I would also need the "rapidminer-studio.log (exactly that one, not the ones ending with numbers) file contents.
I doubleclicked "RapidMiner-Studio.bat" file at my C:\Program Files\RapidMiner\RapidMinern Studio, It show cmd.exe as the below image. If there are confused process, can you remote at my notebook? I am in Thailand.
Thank you! I do not know why, but there is a file in your .RapidMiner folder which is broken: "lastversion". Please post the content here for me as I'm curious, and then just delete that file and try again. It should now start no problem.
I printscreened the files in .RapidMiner Folder. Moreover, there are not files in the subfolders : buildingblocks, extensions, licecses and shared date but there are file in the internal cache subfolder.
I meant show me what's inside the "lastversion" file, please.
Also then just delete it and try starting Studio again.
I doubleclick at lastversion file, it show the below image. Now I do not delete this file.
please just delete the file and then start Studio again.
Thank you very much for the help of RapidMiner team. I can open RapidMiner V.9.0. I only deleted lastversion file and doubleclick at program. It can open to use as the below image. Thank you aganin.
