Hi
I have a question and i hope you help me.
How can I change the weight relation parameter of Select by Weight operator automatically?
Hi @m_gholami1991,
Can you be more explicit ?
Can you give an example of what you want to do ?
Lionel
hi Mr.lionelderkrikor
I have three problems with the Rapidminer and I hope you can guide you.
I have a data set labeled by a specialist and I want to obtain it’s accuracy. In the first step, the label column of the data is removed and based on 3 features(Select by Weight Operator used), the k-means clustering with 3 cluster has been applied to it. On the other hand, the same dataset with labeled column as the test dataset is implemented in the model. I have three problem in this senario.
