Linear Discriminant Analysis with polynomial label
s96142
s96142 New Altair Community Member
edited November 5 in Community Q&A
Does "Linear Discriminant Analysis" can process "polynomial" label?
The "F1" help information of the operator show "support polynomial label"
but with polynomial label dataset as input,run process will show error
I use the lasted V8.2 versionI, and I see some v6.xx version sample video can process
this is the v8.2 probem?
  • lionelderkrikor
    lionelderkrikor New Altair Community Member
    Hi @s96142,
    I ran some of my processes with LDA and polynominal label using RapidMiner 8.2 and RapidMiner 9.0 :
    RapidMiner don't raise an error....
    So are you sure to have effectively set your label as "polynominal" ? (maybe your label is initialy "numerical"....)
    Can you share your process and your dataset(s) in order we can reproduce what you observe ?
    Lionel
  • s96142
    I practice the sample in "Data Mining for The masses" which download from your website(page 124/264).
    Below is error message:
  • s96142
    This is my process and dataset.
  • lionelderkrikor
    Answer ✓
    Hi again @s96142,
    You made a mistake in the parameters of the Filter Examples operator. Here the right filters :
    and the corrected process :
    <?xml version="1.0" encoding="UTF-8"?><process version="9.0.000-BETA">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="9.0.000-BETA" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_csv" compatibility="9.0.000-BETA" expanded="true" height="68" name="Read CSV" width="90" x="45" y="85">
    <parameter key="csv_file" value="C:\Users\Lionel\Downloads\Chapter07DataSet_Training.csv"/>
    <parameter key="column_separators" value=","/>
    <parameter key="skip_comments" value="true"/>
    <parameter key="date_format" value="MMM d, yyyy h:mm:ss a z"/>
    <list key="annotations"/>
    <parameter key="encoding" value="windows-1252"/>
    <parameter key="0" value="Age.true.real.attribute"/>
    <parameter key="1" value="Strength.true.integer.attribute"/>
    <parameter key="2" value="Quickness.true.integer.attribute"/>
    <parameter key="3" value="Injury.true.integer.attribute"/>
    <parameter key="4" value="Vision.true.integer.attribute"/>
    <parameter key="5" value="Endurance.true.integer.attribute"/>
    <parameter key="6" value="Agility.true.integer.attribute"/>
    <parameter key="7" value="Decision_Making.true.integer.attribute"/>
    <parameter key="8" value="Prime_Sport.true.nominal.label"/>
    </list>
    <parameter key="read_not_matching_values_as_missings" value="false"/>
    <operator activated="true" class="filter_examples" compatibility="9.0.000-BETA" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="85">
    <list key="filters_list">
    <parameter key="filters_entry_key" value="Decision_Making.ge.3"/>
    <parameter key="filters_entry_key" value="Decision_Making.le.100"/>
    </list>
    <operator activated="true" class="set_role" compatibility="9.0.000-BETA" expanded="true" height="82" name="Set Role" width="90" x="581" y="85">
    <parameter key="attribute_name" value="Prime_Sport"/>
    <operator activated="true" class="linear_discriminant_analysis" compatibility="9.0.000-BETA" expanded="true" height="82" name="LDA" width="90" x="715" y="85"/>
    <connect from_op="Read CSV" from_port="output" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_op="Set Role" to_port="example set input"/>
    <connect from_op="Set Role" from_port="example set output" to_op="LDA" to_port="training set"/>
    <connect from_op="LDA" from_port="model" to_port="result 1"/>
    <connect from_op="LDA" from_port="exampleSet" to_port="result 2"/>
    </process>
    </process>
    Lionel
  • s96142
    Answer ✓
    After fixing it, the process can run without problem.
    Thank you!
