hi
I am using k-nn algorithm for predict categories of some product with test mining on customers comments.
I have a Q about optimize parameter in classification using k-nn algorithm,
I want to optimize the K with "optimize parameters" and "log" operators for best accuracy in performance,
but I have 2 performance operator in my process below and i don't know where should I put optimize parameters and log process?
and need a help for it
-neginz
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.2.001" expanded="true" height="68" name="Retrieve appended-data-eng" width="90" x="45" y="34">
<parameter key="repository_entry" value="../../data/Digikala-Data/appended-data-eng"/>
<operator activated="true" class="nominal_to_text" compatibility="8.2.001" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="34">
<parameter key="attributes" value="Weakness|Strengths|Content|Title"/>
<operator activated="true" class="select_attributes" compatibility="8.2.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="380" y="34">
<parameter key="attributes" value="Content|Strengths|Title|Weakness|Comment id|Category"/>
<operator activated="true" class="set_role" compatibility="8.2.001" expanded="true" height="82" name="Set Role" width="90" x="514" y="34">
<parameter key="attribute_name" value="Category"/>
<operator activated="true" class="split_data" compatibility="8.2.001" expanded="true" height="103" name="Split Data" width="90" x="112" y="289">
<enumeration key="partitions">
<parameter key="ratio" value="0.7"/>
<parameter key="ratio" value="0.3"/>
</enumeration>
<parameter key="sampling_type" value="shuffled sampling"/>
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="313" y="238">
<parameter key="keep_text" value="true"/>
<parameter key="prune_below_percent" value="0.0"/>
<parameter key="prune_above_percent" value="100.0"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="9999"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34"/>
<operator activated="false" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="112" y="136">
<parameter key="mode" value="linguistic sentences"/>
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="246" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="380" y="34"/>
<operator activated="false" class="text:filter_stopwords_dictionary" compatibility="8.1.000" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="514" y="136">
<parameter key="file" value="E:\payan name\dataminer exention\amazon\New Text Document.txt"/>
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="648" y="34">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="9999"/>
<operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="782" y="34"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="8.1.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="916" y="34">
<parameter key="max_length" value="3"/>
<operator activated="false" class="text:stem_snowball" compatibility="8.1.000" expanded="true" height="68" name="Stem (Snowball)" width="90" x="648" y="340"/>
<operator activated="false" class="text:stem_lovins" compatibility="8.1.000" expanded="true" height="68" name="Stem (Lovins)" width="90" x="246" y="595"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="Cross Validation" width="90" x="514" y="187">
<operator activated="true" class="k_nn" compatibility="8.2.001" expanded="true" height="82" name="k-NN" width="90" x="112" y="34">
<parameter key="k" value="7"/>
<connect from_port="training set" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.2.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="112" y="34">
<operator activated="true" class="performance_classification" compatibility="8.2.001" expanded="true" height="82" name="Performance" width="90" x="313" y="34">
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<operator activated="true" class="free_memory" compatibility="8.2.001" expanded="true" height="82" name="Free Memory" width="90" x="648" y="289"/>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="380" y="442">
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (3)" width="90" x="45" y="34"/>
<operator activated="false" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize (4)" width="90" x="112" y="136">
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="179" y="34"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="380" y="34"/>
<operator activated="false" class="text:filter_stopwords_dictionary" compatibility="8.1.000" expanded="true" height="82" name="Filter Stopwords (3)" width="90" x="514" y="136">
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="648" y="34">
<operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (2)" width="90" x="782" y="34"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="8.1.000" expanded="true" height="68" name="Generate n-Grams (2)" width="90" x="916" y="34">
<operator activated="false" class="text:stem_snowball" compatibility="8.1.000" expanded="true" height="68" name="Stem (3)" width="90" x="648" y="340"/>
<operator activated="false" class="text:stem_lovins" compatibility="8.1.000" expanded="true" height="68" name="Stem (4)" width="90" x="246" y="595"/>
<operator activated="false" class="text:stem_dictionary" compatibility="8.1.000" expanded="true" height="82" name="Stem (5)" width="90" x="380" y="289"/>
<connect from_port="document" to_op="Tokenize (3)" to_port="document"/>
<connect from_op="Tokenize (3)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Generate n-Grams (2)" to_port="document"/>
<connect from_op="Generate n-Grams (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.2.001" expanded="true" height="82" name="Apply Model" width="90" x="849" y="442">
<operator activated="true" class="performance_classification" compatibility="8.2.001" expanded="true" height="82" name="Performance (3)" width="90" x="849" y="187">
<connect from_op="Retrieve appended-data-eng" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 2" to_op="Process Documents from Data (2)" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="word list" to_op="Process Documents from Data (2)" to_port="word list"/>
<connect from_op="Cross Validation" from_port="model" to_op="Free Memory" to_port="through 1"/>
<connect from_op="Free Memory" from_port="through 1" to_op="Apply Model" to_port="model"/>
<connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/>
<connect from_op="Apply Model" from_port="model" to_port="result 3"/>
<connect from_op="Performance (3)" from_port="performance" to_port="result 1"/>
<connect from_op="Performance (3)" from_port="example set" to_port="result 2"/>
</process>
</process>
