Hi Experts,
I've a questions about creating a graph form the results of the FP-Growth operator without using the Create Association Rules operator. Is there a way to visualize the FP-Growth results in a graph?
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="subprocess" compatibility="8.2.001" expanded="true" height="82" name="Crawler" width="90" x="45" y="34">
<operator activated="true" class="subprocess" compatibility="8.2.001" expanded="true" height="82" name="Crawler Spon" width="90" x="45" y="34">
<operator activated="true" class="web:crawl_web_modern" compatibility="7.3.000" expanded="true" height="68" name="Crawl Web" width="90" x="112" y="34">
<parameter key="url" value="http://www.spiegel.de"/>
<list key="crawling_rules">
<parameter key="store_with_matching_url" value=".+www.spiegel.+"/>
<parameter key="follow_link_with_matching_url" value=".+spiegel.+|.+de.+"/>
</list>
<parameter key="max_crawl_depth" value="10"/>
<parameter key="retrieve_as_html" value="true"/>
<parameter key="add_content_as_attribute" value="true"/>
<parameter key="max_pages" value="2000"/>
<parameter key="max_page_size" value="100000"/>
<parameter key="delay" value="100"/>
<parameter key="max_concurrent_connections" value="200"/>
<parameter key="max_connections_per_host" value="100"/>
<parameter key="user_agent" value="Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:57.0) Gecko/20100101 Firefox/57.0"/>
<operator activated="true" class="free_memory" compatibility="8.2.001" expanded="true" height="82" name="Free Memory (8)" width="90" x="246" y="34"/>
<operator activated="true" class="web:retrieve_webpages" compatibility="7.3.000" expanded="true" height="68" name="Get Pages" width="90" x="447" y="34">
<parameter key="link_attribute" value="Link"/>
<parameter key="page_attribute" value="link"/>
<parameter key="random_user_agent" value="true"/>
<operator activated="true" class="free_memory" compatibility="8.2.001" expanded="true" height="82" name="Free Memory (7)" width="90" x="648" y="34"/>
<connect from_op="Crawl Web" from_port="example set" to_op="Free Memory (8)" to_port="through 1"/>
<connect from_op="Free Memory (8)" from_port="through 1" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_op="Free Memory (7)" to_port="through 1"/>
<connect from_op="Free Memory (7)" from_port="through 1" to_port="out 1"/>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data (3)" width="90" x="246" y="34">
<parameter key="create_word_vector" value="false"/>
<parameter key="keep_text" value="true"/>
<list key="specify_weights"/>
<operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content" width="90" x="179" y="34">
<parameter key="ignore_non_html_tags" value="false"/>
<operator activated="true" class="free_memory" compatibility="8.2.001" expanded="true" height="82" name="Free Memory (9)" width="90" x="380" y="34"/>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Free Memory (9)" to_port="through 1"/>
<connect from_op="Free Memory (9)" from_port="through 1" to_port="document 1"/>
</process>
<operator activated="true" class="store" compatibility="8.2.001" expanded="true" height="68" name="Store" width="90" x="514" y="34">
<parameter key="repository_entry" value="../spon-seiten roh"/>
<connect from_op="Crawler Spon" from_port="out 1" to_op="Process Documents from Data (3)" to_port="example set"/>
<connect from_op="Process Documents from Data (3)" from_port="example set" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="out 1"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.2.001" expanded="true" height="124" name="Prepare Data" width="90" x="246" y="34">
<operator activated="true" class="set_role" compatibility="8.2.001" expanded="true" height="82" name="Set Role (2)" width="90" x="45" y="34">
<parameter key="attribute_name" value="text"/>
<list key="set_additional_roles">
<parameter key="Title" value="label"/>
</list>
<operator activated="true" class="generate_id" compatibility="8.2.001" expanded="true" height="82" name="Generate ID" width="90" x="179" y="34"/>
<operator activated="true" class="order_attributes" compatibility="8.2.001" expanded="true" height="82" name="Reorder Attributes" width="90" x="380" y="34">
<parameter key="attribute_ordering" value="Title|text"/>
<operator activated="true" class="select_attributes" compatibility="8.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="34">
<parameter key="attributes" value="text|Title|id"/>
<operator activated="true" class="filter_examples" compatibility="8.2.001" expanded="true" height="103" name="Filter Examples" width="90" x="715" y="34">
<list key="filters_list">
<parameter key="filters_entry_key" value="Title.is_not_missing."/>
</list>
<parameter key="filters_logic_and" value="false"/>
<parameter key="filters_check_metadata" value="false"/>
<operator activated="true" class="multiply" compatibility="8.2.001" expanded="true" height="124" name="Multiply uncut" width="90" x="849" y="34"/>
<connect from_port="in 1" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/>
<connect from_op="Reorder Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Multiply uncut" to_port="input"/>
<connect from_op="Multiply uncut" from_port="output 1" to_port="out 1"/>
<connect from_op="Multiply uncut" from_port="output 2" to_port="out 2"/>
<connect from_op="Multiply uncut" from_port="output 3" to_port="out 3"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
<portSpacing port="sink_out 4" spacing="0"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.2.001" expanded="true" height="82" name="fp Growth" width="90" x="514" y="34">
<operator activated="true" class="text:process_document_from_data" compatibility="8.1.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="313" y="34">
<parameter key="prune_method" value="percentual"/>
<parameter key="prune_below_percent" value="30.0"/>
<parameter key="prune_above_percent" value="100.0"/>
<parameter key="prune_below_absolute" value="20"/>
<parameter key="prune_above_absolute" value="2000"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize Non-letters (4)" width="90" x="45" y="34"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize Linguistic (4)" width="90" x="179" y="34">
<parameter key="mode" value="linguistic sentences"/>
<parameter key="language" value="German"/>
<operator activated="true" class="text:filter_by_length" compatibility="8.1.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="313" y="34">
<parameter key="min_chars" value="2"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="8.1.000" expanded="true" height="68" name="Filter Stopwords (4)" width="90" x="447" y="34"/>
<operator activated="true" class="text:stem_snowball" compatibility="8.1.000" expanded="true" height="68" name="Stem (Snowball)" width="90" x="581" y="34">
<operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases (4)" width="90" x="715" y="34"/>
<operator activated="true" class="free_memory" compatibility="8.2.001" expanded="true" height="82" name="Free Memory (4)" width="90" x="849" y="34"/>
<connect from_port="document" to_op="Tokenize Non-letters (4)" to_port="document"/>
<connect from_op="Tokenize Non-letters (4)" from_port="document" to_op="Tokenize Linguistic (4)" to_port="document"/>
<connect from_op="Tokenize Linguistic (4)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Stopwords (4)" to_port="document"/>
<connect from_op="Filter Stopwords (4)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Transform Cases (4)" to_port="document"/>
<connect from_op="Transform Cases (4)" from_port="document" to_op="Free Memory (4)" to_port="through 1"/>
<connect from_op="Free Memory (4)" from_port="through 1" to_port="document 1"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.2.001" expanded="true" height="82" name="Co-occurrence" width="90" x="514" y="34">
<operator activated="true" class="text_to_nominal" compatibility="8.2.001" expanded="true" height="82" name="Text to Nominal" width="90" x="45" y="34"/>
<operator activated="true" class="numerical_to_binominal" compatibility="8.2.001" expanded="true" height="82" name="Numerical to Binominal" width="90" x="179" y="34"/>
<operator activated="true" class="concurrency:fp_growth" compatibility="8.2.001" expanded="true" height="82" name="FP-Growth" width="90" x="380" y="34">
<parameter key="positive_value" value="true"/>
<parameter key="min_support" value="0.5"/>
<parameter key="min_frequency" value="2"/>
<parameter key="find_min_number_of_itemsets" value="false"/>
<enumeration key="must_contain_list"/>
<connect from_port="in 1" to_op="Text to Nominal" to_port="example set input"/>
<connect from_op="Text to Nominal" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="FP-Growth" to_port="example set"/>
<connect from_op="FP-Growth" from_port="frequent sets" to_port="out 1"/>
</process>
<connect from_port="in 1" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Co-occurrence" to_port="in 1"/>
<connect from_op="Co-occurrence" from_port="out 1" to_port="out 1"/>
</process>
<connect from_op="Crawler" from_port="out 1" to_op="Prepare Data" to_port="in 1"/>
<connect from_op="Prepare Data" from_port="out 1" to_op="fp Growth" to_port="in 1"/>
<connect from_op="fp Growth" from_port="out 1" to_port="result 1"/>
</process>
</process>
best regards
Tobias
