I've been trying to import my csv file with over 3k rows and 29 columns but when i use read csv it only imports 100 rows of data. What can i do to import all the data in the CSV file?
are you referring to the data you see as a preview in the import wizard dialog? Well, that is just a preview which is cut off a some point. It only is there to make sure that the column splits etc. are correctly configured. Just follow the wizard to the end and save the data into a repository, it will load the full data set then.
Hope that helps,
Ingo
