HelloI have friends questions.Is it possible to process image in the rapidshare program? What is the operator?I looked but could not find.Thanks a lotI use version 7.6. Does anyone have a plugin?
@m_keshavarz_com did you even do a search in the community? Yes, there is an image mining operator and there are a lot posts about it.
Hello.Yes, I searched very much in the forum. But I could not use it.I saw a process. I run the program. But I could not download the operator.lookThankful . Maybe help
Hi @m_keshavarz_com,
This extension can be downloaded by following this link : (instructions to install : search on the extension's website and/or in this communauty)
!!!!Note that this extension is not maintained any more!!!!
Personnaly, I tested it, and in most of the cases, RapidMiner raises an error when executed and in fine,
this extension is unusable.
Lionel
@m_keshavarz_com then you should've posted that you tried installing it and it didn't work. I get tired of answering the same questions over and over again when clearly the answers are already in the Community.
