Hi everyone,
I am new to hypermesh, and I find the interface a bit confusing. I want to create a heat flux from an external file. When I import it as a field, the program asks me to select the elements where the flux is applied and then creates a group called convection loads, as well as a load collector. However, when I run the analysis, that load collector turns out to be empty. I dont know how to relate the imported field to the load collector. Thank you very much!!
this is the info box on the group elements created.
this is the load created.
I feel that I am missing an obvious step here but I do not know how to proceed.
As a bonus question, how do I create the load step for this analysis? Would this work?
I do not know if i have to specify a boundary condition, it should not be necesary, as I imputing the flux, right? I dont want to include any temperature loss, just the flux entering the structure.
Thank you all!!
