I am trying to perform an ANOVA. I have data in column A and catagorical information in column B. How do I get the data into a proper format for analysis? Thank you.
Did you take a look at the tutorial process for the ANOVA operator? It shows an example process which includes both the input data format and the output.
Thank you for the suggestion. I am still having trouble. Column A is real numbers. Column B is catagorical data (X,Y,Z). X, Y, and Z. All catagorical data is in one column. I would like to create a new spread sheet with columns titled X, Y, Z. Under each column would be the appropriate data as listed in the original column A.
Hi @dennisk1,
To better understand, can you give an example of :
- the dataset you currently have.
- the dataset you want to obtain.
Lionel
