Generate Attribute with number of specific words in a cell
hi
I am a newbie . . .
I have some excel data and I want to Generate new Attribute with a number of specific word in it, without tokenizing or anything like that
how should I calculate that? can I do this with a regular expression?
for example, I want to count the word "out" in column star and generate new column with the number of the word "out" in it.
sorry for my English
Tnx a lot for your help, it worked very well . . .
but if I have more than one attr column and I want to generate attr for each one it doesn't work with subset attr selection and it'll be too complicated
is there a simple solution for this?
and I have one more Q
how can I count all of the words in one cell and put it in a new column (like this pic)
thank U
Hi @neginz,
Here a process which perform what you want to do :
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="8.2.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34">
<parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Extract_Count_Word\Extract_Count_Word.xlsx"/>
<parameter key="imported_cell_range" value="A1:B5"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="star.true.polynominal.attribute"/>
<parameter key="1" value="out.true.attribute_value.attribute"/>
</list>
<operator activated="true" class="generate_attributes" compatibility="8.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34">
<parameter key="out" value="star"/>
</list>
<operator activated="true" class="set_macro" compatibility="8.2.001" expanded="true" height="82" name="Set word to count" width="90" x="313" y="34">
<parameter key="macro" value="word"/>
<parameter key="value" value="out"/>
<operator activated="true" class="replace" compatibility="8.2.001" expanded="true" height="82" name="Replace" width="90" x="447" y="34">
<parameter key="attribute" value="out"/>
<parameter key="replace_what" value="\b(?!%{word}\b)\w+"/>
<operator activated="true" class="replace" compatibility="8.2.001" expanded="true" height="82" name="Replace (2)" width="90" x="581" y="34">
<parameter key="replace_what" value=","/>
<operator activated="true" class="split" compatibility="8.2.001" expanded="true" height="82" name="Split" width="90" x="715" y="34">
<parameter key="split_pattern" value="[" "]|[" "]"/>
<operator activated="true" class="replace" compatibility="8.2.001" expanded="true" height="82" name="Replace (3)" width="90" x="849" y="34">
<parameter key="attribute_filter_type" value="regular_expression"/>
<parameter key="attribute" value="star"/>
<parameter key="regular_expression" value="out.*"/>
<parameter key="replace_what" value="[" "]"/>
<parameter key="replace_by" value="?"/>
<operator activated="true" class="generate_aggregation" compatibility="8.2.001" expanded="true" height="82" name="Generate Aggregation" width="90" x="983" y="34">
<parameter key="attribute_name" value="out"/>
<parameter key="value_type" value="nominal"/>
<parameter key="aggregation_function" value="count"/>
<operator activated="true" class="select_attributes" compatibility="8.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="1184" y="34">
<parameter key="use_except_expression" value="true"/>
<parameter key="except_regular_expression" value="out"/>
<connect from_op="Read Excel" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Set word to count" to_port="through 1"/>
<connect from_op="Set word to count" from_port="through 1" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/>
<connect from_op="Replace (2)" from_port="example set output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="Replace (3)" to_port="example set input"/>
<connect from_op="Replace (3)" from_port="example set output" to_op="Generate Aggregation" to_port="example set input"/>
<connect from_op="Generate Aggregation" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
You have to set the word to count in the parameters of Set Macro operator (in your case out) :
I hope it helps,
Lionel
Hi @neginz,
I hope it helps,
Lionel
