"KERAS model and Sliding Window Validation"
User: "chinrenjie"
New Altair Community Member
Updated by Jocelyn
I am using sliding validation window and fix the training window width as 100 and testing window width as 100.
The total datasets that I have is 9000.
I want to develop a prediction model using the convolutional neural network in Keras Model.
I get the error as shown below. Can anyone please give some advice? Your help is highly appreciated.
Thank you.
1 - 2 of 21
    User: "rfuentealba"
    Hi @chinrenjie
    On your right process (the testing part), just don't connect the mod port from the Apply Keras extension to the output of the process. This happens because mod is a model and what the res (or, in this case, ave) port is expecting is a data set or some other kind of object (in this case: averagable), and it cannot process a model.
    Whenever you have doubts, just put the mouse pointer on top of the semicircle. Something like this will show you what kind of data does it need (and if there are errors to be fixed):
    Hope this helps.
    User: "chinrenjie"
    OP
    I have tried to not connect the mod port to the output, the similar error happens. May I get advice regarding this issue? Thank you very much.
    Ren Jie
