Summary of comments
Hello
I have a question to thank you for answering.
That's what I was looking for, but I did not find it
That
I have a few comments I want to summarize in terms of content in four major categories
Do you know how to do?
This exercise is a data mining course at my university
Thanks a lot
Hi Jozef,
You can check the last webinar by @sgenzer. Although there are some web scraping and API concepts that maybe you don't need, two techniques for classification of chatbot conversations are introduced: K-Means clustering and LDA. They surely apply to your problem.
Sebastian
1 -
Hello
Thank you so much for your answer
Did i get it right? Should I kmeans comments on clustering? And then apply any LDA cluster?
How do I figure out what content is there in each cluster?
(Is it possible to view the shape of clusters and centers?)
Thanks if you help me:smileyhappy:
Waiting...0 -
Hi Jozef,
I'm not sure I understand the questions, but K-means and LDA are two different techniques. Both will assign each sample to one of the clusters. I'm afraid that deciding which to use and with which parameters is problem-dependent and requires a good dose of trial and error.
Regarding the visualization, that would be possible only with two dimensions (like the classic example of the iris dataset).
Sebastian
1 -
thanks so much for your friend @SGolbert
I want to be able to know what content is in each cluster. Can I understand by LDA? How can I use LDA to find the best K? Thanks if you help With respect
