I had a gradient boosted tree classification model, generated using the Auto Model, that produced a 70% f-measure for a given dependent variable value…but then I input random numbers for the dependent variable and ran a GBT model again, with the same exact example data, and the f-measure was 65%. So closer than I had expected, and wondering how that can be the case. Thank you.
