Remove duplicates
User: "ga34hox"
New Altair Community Member
Updated by Jocelyn
Hello everbody,
i hope somebody can help. I've got a data set of about 50000 rows and 2 columns (att1, att2). I wanna remove duplicates in which (and only if) the value of att1(row1) is equal to value of att2(row2) and value off att2(row1) is equal to att1(row2).
Example:
            att1   att2
row1  100    200
row2   200   100
Sow row2 will be eliminated. Anybody an idea/solution?
Thanks so much!
1 - 3 of 31
    User: "lionelderkrikor"
    Hi @ga34hox,
    I think that the Lag Series operator from the Value Series extension can help you.
    Does this process answer to your need ? (I just tested it on a partial dataset) :
    <?xml version="1.0" encoding="UTF-8"?><process version="8.2.000">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="read_excel" compatibility="8.2.000" expanded="true" height="68" name="Read Excel" width="90" x="112" y="34">
    <parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\Tests_Rapidminer\Remove_Duplicates\Remove_Duplicates.xlsx"/>
    <parameter key="imported_cell_range" value="A1:B7"/>
    <parameter key="first_row_as_names" value="false"/>
    <list key="annotations">
    <parameter key="0" value="Name"/>
    </list>
    <parameter key="0" value="Att1.true.integer.attribute"/>
    <parameter key="1" value="Att2.true.integer.attribute"/>
    </list>
    <operator activated="true" class="series:lag_series" compatibility="7.4.000" expanded="true" height="82" name="Lag Series" width="90" x="246" y="34">
    <list key="attributes">
    <parameter key="Att1" value="1"/>
    <parameter key="Att2" value="1"/>
    </list>
    <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="34">
    <parameter key="Duplicates" value="if((Att1==[Att2-1])&amp;&amp;(Att2==[Att1-1]),1,0)"/>
    </list>
    <operator activated="true" class="filter_examples" compatibility="8.2.000" expanded="true" height="103" name="Filter Examples" width="90" x="514" y="34">
    <parameter key="parameter_string" value="Duplicates &lt;&gt; 1"/>
    <parameter key="condition_class" value="attribute_value_filter"/>
    <list key="filters_list"/>
    <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="648" y="34">
    <parameter key="attributes" value="Att1|Att2"/>
    <connect from_op="Read Excel" from_port="output" to_op="Lag Series" to_port="example set input"/>
    <connect from_op="Lag Series" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
    <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
    </process>
    </process>
    Lionel
    User: "ga34hox"
    OP
    lionelderkrikor
    thanks for your answer. But i have not yet recognized how this operator can help me. Can you explain in more detail?
    Hi @ga34hox,
    Have you try to import and execute the process I shared ?
    This operator allow to shift the data of a column.
    To better understand set Breakpoints on the different operators to see the different transformation/calculations on the data.
    Lionel
